Location of product card template
Multi Vendor Marketplace Plugin | WCFM Marketplace Forums Product Vendors Location of product card template
This topic contains 8 replies, has 2 voices, and was last updated by WCFM Forum WCFM Forum 6 hours, 54 minutes ago.
  • #85626
    Avatar
    jorsenmejia
    This is an elementor widget where can I edit the box? please refer to the screenshot
    I want to override the template
  • #85629
    Avatar
    jorsenmejia
    I found the name and under the name template, I can’t find the product name template
  • #85799
    Avatar
    jorsenmejia
    How can I echo vendor address? using custom code?
  • #86222
    Avatar
    jorsenmejia
    I got an error when I installing geo location help me fix please
  • #86435
    Keymaster
    – User this short code – [wcfm_store_info id="STORE ID" data="address"]
    Set “store id” in short code and it will show address for the store.
    – Do you mean GEO my WP plugin?
    What error, please show me screenshot for this.
  • #86437
    Avatar
    jorsenmejia
    I want the dynamic code “User this short code – [wcfm_store_info id=”STORE ID” data=”address”]
    Set “store id” in short code and it will show address for the store.”
  • #86438
    Avatar
    jorsenmejia
    After I install geolocation my whole website got an error
  • #86439
    Avatar
    jorsenmejia
    Please check the error
  • #86776
    Keymaster
    What is GEO Location? Which plugin?
You must be logged in to reply to this topic.
