Problem on Vendor statistics
This topic contains 1 reply, has 2 voices, and was last updated by WCFM Forum WCFM Forum 3 months, 1 week ago.
  • #85492
    I have an issue on number of views statistics.
    On the vendor dashboard, there are days when it does not work.
    On the admin dashboard, it is the same.
    I notice that when it works on admin dashboard, it doesn’t work on vendor dashboard and vice versa.
    screenshot attached of both vendor dashboard and admin dashboard.
    Have you a solution to solve this issue ?
    WCFM – WooCommerce Frontend Manager v6.3.1
    Regards,
    Aurélien.
  • #86253
    Keymaster
    Well, how you can compare these two stats?
    Admin see WooCommerce default shop page view stats. But vendor sees only his/her own store page view stats.
    Those will never match!
    Still we are debugging this, if there has any fault or not!
You must be logged in to reply to this topic.
