Product Variations not saving
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Product Variations not saving
Viewing 7 reply threads
    • #49872
      redantscaribbean
      Good Day,
      Whenever I attempt to create a Product Variation it does not save on WCFM. If it do it from Woocommerce side it saves properly. Please assist
    • #49908
      Is this working perfectly, if you are trying to save “Simple” product?
      Is product creating and only variations are not saving, or product also not creating!
    • #49909
      redantscaribbean
      Simple product works perfectly.
      The product is creating, however no variations are saving. I tested it on your demo site also and it gives the same issue.
    • #49928
      I have just created a variable product at our demo for you – https://www.useloom.com/share/4029c8d7d2f74e88a74b27ea950237b2
      Product – http://wcfmmp.wcfmdemos.com/product/variation-test/
    • #50027
      redantscaribbean
      Can you tell me what is the current version that the demo is using?
    • #50107
      Demo is running with all latest version of plugins.
      WCFM – 5.4.2
      WCFM Marketplace – 2.2.2
    • #50176
      redantscaribbean
      Thank you again. It suddenly started working after I deactivated and reactivated the plugin. Thank you very much!
    • #50206
      Great … thanks for the update 🙂
  • The topic ‘Product Variations not saving’ is closed to new replies.
