shortcode [wcfm_stores include_membership="membership type"] not working
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Marketplace (WooCommerce Multivendor Marketplace) shortcode [wcfm_stores include_membership="membership type"] not working
Viewing 1 reply thread
    • #133750
      rkostkas
      Hi, tried to use shortcode [wcfm_stores include_membership=”member”] to display only those stores that belong to a certain membership type (which is tied to a Group), but it’s not working. Did I used the syntax correctly? If not, what is the correct syntax? If my syntax is correct, please help fix the issue. Thanks!
    • #134118
      You have to add membership id in the shortcode-
      [wcfm_stores per_row=3 include_membership="3"]
      replace 3 with your membership id. (https://docs.wclovers.com/store-list/)
