Single product multi vendor – Product suggestions
Viewing 1 reply thread
    • #118650
      kingoftheroad
      Hi. In search for a solution i found this thread https://wclovers.com/forums/topic/single-product-multiple-vendor/
      Here the module is described with the exact functionality i need.
      I tested it and it doesn’t seem to work this way anymore.
      I need vendors to get product suggestion when they start typing the title.
      I want the store to display multiple instances of the same product if more vendors are selling it.
      Is it possible to do this in the current version?
    • #120355
      kingoftheroad
      Can someone help me please?
