Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › WooCommerce Product Scheduler integration
- This topic has 7 replies, 4 voices, and was last updated 7 years, 10 months ago by
- October 5, 2017 at 10:47 pm #13955
Lourenco.cf
ParticipantHi.
Another good integration as any kind of scheduler the start ant end dates of avaiability of the product or productcs.
Something like this addon abovehttps://codecanyon.net/item/woocommerce-product-scheduler/11615247
Thanks again. And great job.
- October 6, 2017 at 1:52 am #13965
Shhiv Narayan
Thanks for this.
I will look into this soon and know you the update.Thanks for your cooperation.
- October 6, 2017 at 9:51 pm #13982
Lourenco.cf
More easy!
If i can add two date fields with ACF, why not make these two fields start and end dates scheduler?Why not?!
Thanks - October 7, 2017 at 4:48 pm #14020
WCFM has it’s own Custom Field, and that is only for such third party integration.
WE have even integrate “Affiliate WP” using this.Please take a look here for the documentation:
http://wclovers.com/knowledgebase/wcfm-custom-fields/Can you please share me this plugin then I will help you to setup WCFM custom field!!
Please don’t attach plugin here, upload in google drive and share with wclovers.contact@gmail.comThank You
- October 8, 2017 at 11:46 am #14037
Lourenco.cf
ParticipantHi again,
and thank you for your repply…
I discovery one more simple way to integration.
The free wordpress.org plugin by cedcommerce
https://wordpress.org/plugins/wp-content-scheduler-with-range/Can schedule any kind of post type.
If you need the files, tell me.
- October 8, 2017 at 1:33 pm #14039
WCfM Forum
Let me check that.
It’s available in wordpress.org so don’t need file of this.
Previously you have mentioned a codycaneon plugin so I have had asked for the files.
Let me check is this possible to integrate using WCFM custom field or not !!
- October 9, 2017 at 8:32 am #14092
I have setup this plugin using WCFM custom field, it’s possible.
PFA for custom field setup.
But I have doubt about this plugin, not updated for a long time and whether it working properly or not.
I have already noticed that it has some coding/CSS issues.Please test properly before going to use this.
You must be logged in to view attached files. - October 20, 2017 at 8:39 pm #14627
MemberPlease check here for further communication – http://wclovers.com/forums/topic/woocommerce-product-scheduler-integration-2/
- The topic ‘WooCommerce Product Scheduler integration’ is closed to new replies.
