WooCommerce Product Scheduler integration – 2
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate WooCommerce Product Scheduler integration – 2
Viewing 8 reply threads
    • #14540
      Lourenco.cf
      Original thread – http://wclovers.com/forums/topic/woocommerce-product-scheduler-integration/
      I resolved to open the topic with the same subject, to divulge to everyone how easily I resolved.
      Add one ACF data picker field, for end date.
      Next add to the fuctions.php a cron scheduler, some like these..
      When read the date from the custom acf field, put the product in draft.. our can delete… our something.
      Easy.
      // expire products on date field.
      if (!wp_next_scheduled('expire_posts')){
        wp_schedule_event(time(), 'daily', 'expire_posts'); // this can be hourly, twicedaily, or daily
      add_action('expire_posts', 'expire_posts_function');
      function expire_posts_function() {
      	$today = date('Ymd');
      	$args = array(
      		'post_type' => array('product'), // post types you want to check
      		'posts_per_page' => -1
      	$posts = get_posts($args);
      	foreach($posts as $p){
      		$expiredate = get_field('end_date', $p->ID, false, false); // get the raw date from the db
      		if ($expiredate) {
      			if($expiredate < $today){
      				$postdata = array(
      					'ID' => $p->ID,
      					'post_status' => 'draft'
      				wp_update_post($postdata);
      You can tweak the code to publish the product to…
      Only add another field “start date”.
    • #14544
      WCfM Forum
      Again I don’t know how to say you thanks for this!!
      I am sorry because old post automatically closed after certain time.
      It’s pleasure for me to have a user like you.
      Thank you very much mate !!
      Shhiv
    • #14551
      memtimintursun
      This is reply for the closed topic; http://wclovers.com/forums/topic/questions-before-but-this/
      Whatever I do, it doesn’t work. I did many times what you said.
      I am almost giving up this if this doesn’t work for me.
    • #14560
      WCfM Forum
      I am sorry as topics are automatically closed for a certain period inactivity!!
      Please tell me what kind of issues you are now facing?
      What can I do for you ?
    • #14567
      memtimintursun
      EbayImport shows on menu, when you click it, not found page. but it was working on 3.17 version, after you updated to 3.20 version, it’s gone, no more working. when I am asking, you saying same things, it should work, do this, that. but with out you saying it, I did already tried those steps. but it’s not working.
      shortly, is there possible to include custom menu and for that menu addon from woocommerce?
      I want to give this possibilities only for paid memebers. however, even I can’t integrate it in the free version, what is point to buy ultimate version, if it doesn’t work?
      for that reason, I am almost giving up.
    • #14576
      WCfM Forum
      I am not sure why it’s not working for you!!
      But if such things not working for WCFM then it’s all add-ons are going to be useless.
      WCFM only offers five main menus – Product, Order, Coupon and Settings
      But all other menu items are added externally using add-ons, you can check any of our demos.
      I want to resolve this for you, if you can share a demo access with me then I will take a look in depth of this.
    • #14584
      memtimintursun
      Did you mean “demo admin” or “demo vendor”?
    • #14586
      WCfM Forum
      Demo admin prferred!!
      Thanks for your cooperation ..
    • #14629
      Hi @memtimintursun,
      I am closing this thread as it’s context something else.
      Please share your site access not here, at mail – wclovers.contact@gmail.com
      Looking forward to hear from you soon.
  • The topic ‘WooCommerce Product Scheduler integration – 2’ is closed to new replies.
