Durga Puja
00Day 14Hr 28Min 24Sec
Durga Puja
A little php help with simple auction integration?
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › A little php help with simple auction integration?
Viewing 8 reply threads
    • #109118
      James Bieniek
      I am looking to make auction listing more uniform/streamlined.
      I don’t want users to have to select the start date, end date, and relisting duration – I want these to be hard-coded to be uniform.
      I managed to get an instant auction start using “timestamp”. I then needed help coding 14 days duration. He came up with some new bits, but i am having trouble, it gets over-ridden or whatever. I am sure this is simple for anyone that knows php and a bit about this plugin. Below is specifically what im looking at with some extra comments:
      /* He gave me this 3 lines instead of ‘timestamp’ – add two variables */
      $_format=”Y-m-d h:m:s”; //format of the date (I like m-d-Y, but seems the actual auction plugin displays it anyway.)
      $_CurrentTime=new DateTime(); //get current date from system
      $_Current_to=$_CurrentTime->add(new DateInterval(‘P14D’)); // add 14 days to the current day
      ^I assume that will work one way or another…
      $product_id = 0;
      $_auction_item_condition = ‘new’;
      $_auction_type = ‘normal’;
      $_auction_proxy = get_option(‘simple_auctions_proxy_auction_on’, ‘no’);
      $_auction_sealed = ‘no’;
      $_auction_start_price = ”;
      $_auction_bid_increment = ”;
      $_auction_reserved_price = ”;
      $_regular_price = ”;
      ^all this above is fine, just added for context
      $_auction_dates_from = ‘$_CurrentTime->format($_format)’; <-this apparently works
      $_auction_dates_to = ‘$_Current_to->format($_format)’; <-perhaps this will work if I remove some code from bottom of file or just css display:none? lol
      $relist_auction_dates_from = ”;
      $relist_auction_dates_to = ”; <-IDK about these 2 considering above edits, regardless I would like 14 days relisting, only option: yes/no which is already there via checkbox
      $_auction_automatic_relist = ”;
      $_auction_relist_fail_time = ”;
      $_auction_relist_not_paid_time = ”;
      $_auction_relist_duration = ”; <- simply type: “14 days”?
      …Below would be more code (you may see all in attached file) I think some of it needs to be removed for above edits to work correctly?
    • #109119
      James Bieniek
      Here is the whole code (hopefully)…I needed to change to txt file
    • #109872
      Please do not edit template, add this code to your site for the purpose –
      add_filter( 'wcfm_product_manage_wcsauction_fields', function( $auction_fileds, $product_id ) {
        if( !$product_id ) {
        	$_format = "Y-m-d h:m:s";
        	$_CurrentTime = new DateTime();
        	if( isset( $auction_fileds['_auction_dates_from'] ) ) {
        		$auction_fileds['_auction_dates_from']['value'] = $_CurrentTime->format($_format);
      		if( isset( $auction_fileds['_auction_dates_to'] ) ) {
      			$_Current_to = $_CurrentTime->add(new DateInterval('P14D'));
      			$auction_fileds['_auction_dates_to']['value'] = $_Current_to->format($_format);
        $auction_fileds = wcfm_hide_field( '_auction_dates_from', $auction_fileds );
        $auction_fileds = wcfm_hide_field( '_auction_dates_to', $auction_fileds );
        return $auction_fileds;
      }, 50, 2 );
    • #115039
      Auhouse.ru
      I need the same code, only for 24 hours
    • #115285
      OK, please try this revised code –
      			$_Current_to = $_CurrentTime->add(new DateInterval('P1D'));
      }, 50, 2 );
    • #115297
      Auhouse.ru
      I added the code, I added the auction and it lasts 8 hours, I need 24 hours
    • #115550
      Please use this revised code –
        	$_format = "Y-m-d H:i";
        	$_CurrentTime = current_time( 'timestamp', 0 );
        		$auction_fileds['_auction_dates_from']['value'] = date( $_format, $_CurrentTime );
      			$auction_fileds['_auction_dates_to']['value'] = date( $_format, strtotime('+1 day', $_CurrentTime ) );
      }, 50, 2 );
    • #118478
      Auhouse.ru
      The code works for new products. When transferring from ordinary goods to auction, dates are not set
    • #125658
      Auhouse.ru
      Hello, is there a solution?
  • The topic ‘A little php help with simple auction integration?’ is closed to new replies.
