Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › About Attributes symbol of variable product
- This topic has 5 replies, 2 voices, and was last updated 6 years, 11 months ago by
Viewing 5 reply threads
- August 22, 2018 at 2:33 am #29139
MOHO
ParticipantWooCommerce variable product use “|” as Attributes symbol
Could we use other symbol such as “,”?
Because the normal user only a few use “|” this symbol when typing.
If could change, WCfM dashboard Must support the new Attributes symbol “,”
By Moho
You must be logged in to view attached files. - August 22, 2018 at 4:31 am #29149
Off course you can change this.
Define this constant in your site’s wp-config.php –
define( 'WC_DELIMITER', ',' );
- August 22, 2018 at 7:55 am #29162
- August 22, 2018 at 8:17 am #29166
That’s strange.
This is WooCommerce default feature and I have tested this.
Check attached video.
You must be logged in to view attached files. - August 24, 2018 at 2:01 am #29426
- August 24, 2018 at 7:15 am #29470
MemberRight, it should be defined before WP load.
thank you
- The topic ‘About Attributes symbol of variable product’ is closed to new replies.
