Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › About INTEGRATIONS with Toolset plugin problem
- This topic has 7 replies, 2 voices, and was last updated 6 years, 9 months ago by
- October 24, 2018 at 10:42 am #34723
- October 24, 2018 at 1:41 pm #34743
I am really sorry if you are having trouble for creating topic here.
Well, you may create Custom Taxonomies using any plugin or may be by writing own code.
WCFM has no restriction that you have to create taxonomies using Toolset.
WCFM will check whether product taxonomy is there or not!
- October 24, 2018 at 4:46 pm #34787
MOHO
ParticipantThanks
“WCFM has no restriction that you have to create taxonomies using Toolset.”
WCFM will display all my custom taxonomies “using any plugin or may be by writing own code”?
- October 25, 2018 at 3:42 am #34871
“using any plugin or may be by writing own code”? – yeah right
- October 25, 2018 at 3:44 am #34872
MOHO
ParticipantHow could make this?
Need any INTEGRATIONS code?
- October 25, 2018 at 5:11 am #34904
Do you want to create this using custom coding, then may check this – https://codex.wordpress.org/Taxonomies
- October 25, 2018 at 5:12 am #34905
MOHO
Participantthanks WCFM
I will give my partner to make it.
- October 25, 2018 at 7:27 am #34917
MemberSure, please know me if any help required form my end.
- The topic ‘About INTEGRATIONS with Toolset plugin problem’ is closed to new replies.
