Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › About notification sounds
- This topic has 5 replies, 3 voices, and was last updated 6 years, 11 months ago by
MOHO.
- August 23, 2018 at 2:49 pm #29380
MOHO
ParticipantI have the same question:
“Some of my testing users feels annoyed with the notification sounds, possible to have option to mute / change / lower the volume ?”Could give each vendor to enable/disable option?
- August 24, 2018 at 5:29 pm #29562
Well, you may add this to disable WCFM dashboard sounds –
add_filter( 'wcfm_is_allow_sound', '__return_false' );
- August 24, 2018 at 5:49 pm #29584
d-n-13
This will disable sound for all vendors, I think it will be great feature for vendors to have the option to disable it individually if they want to, so other vendors can keep it.
- August 24, 2018 at 5:55 pm #29585
- August 24, 2018 at 7:21 pm #29609
Off course it’s possible to add such setting options but that will burden over vendors.
Already vendor setting panel is quite long, then sound enable/disable setting, not a good idea for a very common user as they are not techsavy!
Well, adding custom setting is also possible in WCFM setting panel from outside.
- August 24, 2018 at 7:31 pm #29615
MOHO
Participantok i got it.
you could close it.
- The topic ‘About notification sounds’ is closed to new replies.
