Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › About Toolset with variable product question
- This topic has 23 replies, 2 voices, and was last updated 8 years, 2 months ago by
- August 2, 2018 at 2:48 am #27448
- August 2, 2018 at 3:59 am #27455
MOHO
ParticipantI have solved this problem, i should use Taxonomy.
You could closed this entry, thanks.
- August 4, 2018 at 4:59 am #27557
MemberOK, that’s fine π
- August 4, 2018 at 6:15 am #27573
- August 4, 2018 at 6:31 am #27588
It’s not possible, Toolset or WooCommerce none of them support this.
If you really want to have custom field for variations then we have to develop this custom, no third plugin can be helpful here.
- August 4, 2018 at 8:29 pm #27634
MOHO
ParticipantYes i need “custom field for variations”
I need three number fields as follows:
1. Wholesale Price
2. Cost Price (Required)
3. Maximum Points DiscountI make our custom point reward system, so i need “custom field for variations”.
You must be logged in to view attached files. - August 5, 2018 at 5:15 pm #27713
OK, I understand your requirement.
Kindly know me, are you using any plugin for the purpose?
- August 6, 2018 at 2:21 am #27718
MOHO
ParticipantNo plugin could add field at variations option, right?
I need three number fields at each variation options as follows:
1. Wholesale Price ( meta:_wc_wholesale_price ) –> i custom field
2. Cost Price “Required field” ( meta:_wc_cost_price ) –> i custom field
3. Maximum Points Discount ( meta:_wc_points_max_discount ) –> this woo point plugin fieldCould you custom it for me?
You must be logged in to view attached files. - August 6, 2018 at 7:58 am #27751
MOHO
Participanti need add one more field: “Enable Wholesale Price” option field (yes|no) (meta:_wc_enable_wholesale_price)
If vendor choose “yes”, then display ” Wholesale Price” field
If vendor choose “no”, then hide ” Wholesale Price” fieldMaximum Points Discount field default value = “0”
About translate custom field
Enable Wholesale Price β εη¨ηΆι·εΉ (yes|no β ζ―|ε¦)
Wholesale Price β ηΆι·εΉ
Cost Price β εΊθ²¨εΉ
Maximum Points Discount β ζ΅η¨ιζι«δΈιIf
Wholesale Price < Cost Price
Cost Price < Maximum Points Discount
then display error message - August 6, 2018 at 10:56 am #27767
Kindly know me which plugin you are using for the purpose!
- August 6, 2018 at 10:51 pm #27805
MOHO
ParticipantThis reply has been marked as private. - August 8, 2018 at 3:58 am #27870
We are going to make compatible WCFM with this wholesale plugin – https://wordpress.org/plugins/wholesale-market/
Do you ever tried this?
- August 8, 2018 at 5:05 am #27881
MOHO
ParticipantI try it, but now i no need Wholesale Price.
I use my custom plugin for point count, so i only need variable option add extra two field, can save my meta field:
1. Cost Price β εΊθ²¨εΉ (number field)
2. Maximum Points Discount β ζ΅η¨ιζι«δΈι (number field) - August 8, 2018 at 5:10 am #27885
PFA, a code snippet which help you to add-save custom field for simple and variable products.
Please try this.
thank you
You must be logged in to view attached files. - August 8, 2018 at 6:18 am #27898
- August 8, 2018 at 6:39 am #27901
Just add this code then, it will add a new variation field “MRP Price” –
// Adding variation field function wcfm_product_manage_fields_variations_mpr( $variation_fileds, $variations, $variation_shipping_option_array, $variation_tax_classes_options ) { global $WCFM, $WCFMu; $mrp_price_fields = array( "mrp_price" => array('label' => __('MRP Price', 'wc-frontend-manager-ultimate') , 'type' => 'text', 'class' => 'wcfm-text wcfm_ele variable', 'label_class' => 'wcfm_title wcfm_ele variable' ), ); $variation_fileds = array_merge( $variation_fileds, $mrp_price_fields); return $variation_fileds; } add_filter( 'wcfm_product_manage_fields_variations', 'wcfm_product_manage_fields_variations_mpr', 100, 4 ); // Adding variation field data function wcfm_product_data_variations_mrp( $variations, $variation_id, $variation_id_key ) { global $WCFM, $WCFMu; if( $variation_id ) { $variations[$variation_id_key]['mrp_price'] = get_post_meta( $variation_id, 'mrp_price', true ); } return $variations; } add_filter( 'wcfm_variation_edit_data', 'wcfm_product_data_variations_mrp', 100, 3 ); // Saving variation field data function wcfm_product_variation_save_mrp( $wcfm_variation_data, $new_product_id, $variation_id, $variations, $wcfm_products_manage_form_data ) { global $WCFM, $WCFMu; if( $variation_id ) { update_post_meta( $variation_id, 'mrp_price', $variations[ 'mrp_price' ] ); } return $wcfm_variation_data; } add_filter( 'wcfm_product_variation_data_factory', 'wcfm_product_variation_save_mrp', 100, 5 );Thank You
- August 8, 2018 at 7:12 am #27905
- August 8, 2018 at 7:15 am #27907
This is also possible, then you have to tweak this code a bit and add field at particular position.
Can you do this? OR should I write that code for you?
- August 8, 2018 at 7:29 am #27908
- August 8, 2018 at 8:51 am #27921
MOHO
Participantand how could make field required?
- August 9, 2018 at 1:26 am #27954
MOHO
ParticipantHi i think no need move custom field position, just “make field required”, thanks.
- August 9, 2018 at 3:11 pm #28042
OK, for this kindly update this line –
$mrp_price_fields = array( "mrp_price" => array('label' => __('MRP Price', 'wc-frontend-manager-ultimate') , 'type' => 'text', 'class' => 'wcfm-text wcfm_ele variable', 'label_class' => 'wcfm_title wcfm_ele variable' ), );with this –
$mrp_price_fields = array( "mrp_price" => array('label' => __('MRP Price', 'wc-frontend-manager-ultimate') , 'custom_attributes' => array( 'required' => true ), 'type' => 'text', 'class' => 'wcfm-text wcfm_ele variable', 'label_class' => 'wcfm_title wcfm_ele variable' ), );I have added a new element in array – ‘custom_attributes’ => array( ‘required’ => true )
In WCFM if you add this to any field then it will become “Required” and validation automatically start working.
Hope this will helpful for you π
- August 9, 2018 at 4:14 pm #28063
MOHO
Participantthanks, it work now!
please close it. - August 9, 2018 at 4:16 pm #28065
MemberGreat π
- The topic ‘About Toolset with variable product question’ is closed to new replies.
