About vendor store
Viewing 4 reply threads
    • #103346
      jorsenmejia
      how can I get the “about” content on vendor page and put it on the shop page of his/her product
    • #103393
      jorsenmejia
      I tried this code
      function additional_information_callback() {
      global $WCFM, $WCFMmp;
      $store_user = wcfmmp_get_store( $vendor_id );
      $store_info = $store_user->get_shop_info();
      $gravatar = $store_user->get_avatar();
      $email = $store_user->get_email();
      $phone = $store_user->get_phone();
      $address = $store_user->get_address_string();
      $about = $store_user->get_shop_description();
      echo $about;
      When I try to echo the email,
      If customer user logged in and check the product he sees his own email
    • #103495
      I think you are not getting the correct vendor id. I hope you are trying to get these values in product details page….right?
      If yes then please use the below code to get the vendor id:
      $vendor_id = wcfm_get_vendor_id_by_post( get_the_ID() );
      It will return the correct vendor id and by passing this id you will get the correct values as well.
      Hope this helps.
    • #104829
      trapti agrawal
      Could you please suggest the complete code to add, for the same. thanks.
    • #105191
      Hi @trapti agrawal,
      What complete code do you want?
      You can use the above code just be sure to get the vendor id correct.
  • The topic ‘About vendor store’ is closed to new replies.
