Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › ACF – Conditional Logic
- This topic has 4 replies, 2 voices, and was last updated 6 years, 5 months ago by
The Garden Emporium.
- February 8, 2019 at 12:57 pm #47258
The Garden Emporium
I have setup some select fields on ACF and the fields have conditional logic but this does not work in the frontend adding a product.
Example
Select 1 – Car or Motorcycle
Select 2 – If Car is selected show Car Make – with options (Ford, Vauxhall, Renault)
Select 3 – If Ford is selected Show Car Model (Ford) – with options
Select 3 – If Vauxhall is selected Show Car Model (Vauxhall) – with optionsWhen I use this on the wp-admin backend on add product it works by only showing the select 1 until a option has been selected and then Select 2 will show and once option is selected on Select 2 the Select 3 then shows up.
But on the WCFM front end, when I go to the add product and go to the group for my feilds all of them display?
I have attached some pictures for you to see.
I hope you understand what I have put.
Can this be sorted out please.
- February 8, 2019 at 1:04 pm #47263
The Garden Emporium
ParticipantI have tried to send the pictures again
You must be logged in to view attached files. - February 8, 2019 at 3:12 pm #47284
Thanks for all the Details.
Well, WCFM not yet support such conditional logics.
But we will implement this very soon.
- February 8, 2019 at 5:08 pm #47292
The Garden Emporium
Thanks for the reply, will look forward to this being added.
- February 14, 2019 at 3:55 pm #48243
The Garden Emporium
Any update on this?
Plus I would like to use the layout functions on ACF (Accordion & tabs) works on admin but does not work on WCFM Front End, is this something that can be added aswell please.
Best Regards
Robert
- The topic ‘ACF – Conditional Logic’ is closed to new replies.
