Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › ACF CustomFields integration
- This topic has 21 replies, 4 voices, and was last updated 7 years, 11 months ago by
- September 3, 2017 at 3:26 pm #12815
Sotnas
GuestI’m interested in the plugin but trying the demo and looking at the code is not compatible with the “ACF custom fields”.
Would it be possible to make it compatible, and how long?
thank you - September 3, 2017 at 3:50 pm #12816
Shhiv Narayan
Thanks for get in touch with us and pleasure to know that you are very interested in WCfM.
Our team is already working on that and very soon WCFM will be compatible with ACF.
But right now it’s fully compatible with Toolset – did you check that yet !!
Hopefully this will also fulfill your custom requirements.
http://wclovers.com/knowledgebase/wcfm-toolset-types/Please take a look.
- September 6, 2017 at 7:49 am #12951
Shhiv Narayan
WCfM 3.0.4 is there.
It’s fully compatible with Advanced Custom Fields (ACF).
Here is the documentation –
http://wclovers.com/knowledgebase/wcfm-advanced-custom-fields-acf/A must awaited integration, hope this will useful for all WCfM users.
If anyone has any suggestions regarding this then please feel free to share with us.
- September 11, 2017 at 11:09 am #13161
Sotnas
GuestBecause i need two field types
QRcode and PDF file…
Thanks again
- September 11, 2017 at 11:06 am #13160
Sotnas
GuestExcelent news Shhiv!
Only have one more question.
– Compatibility with fields type, image and upload file?Thanks
- September 11, 2017 at 10:18 pm #13211
MemberAhh … just relax, it’s already in our list.
In WCFM 3.0.6 (next version) you will have support of Image and File type field support for ACF and Toolset both.Thank You
- September 12, 2017 at 6:51 pm #13220
Lourenco.cf
ParticipantOnly good news…!
For when these version?Thanks
- September 13, 2017 at 6:23 pm #13247
Memberwithin 1-2 days.
Thanks for your patience..
- September 16, 2017 at 6:57 pm #13354
Lourenco.cf
ParticipantHi again,
I upgrade to the last version 3.1.0, and don’t see support for file type in acf custom fields.
- September 17, 2017 at 8:34 am #13368
WCfM Forum
GuestLet us check, it’s quite strange.
- September 17, 2017 at 8:56 am #13370
WCfM Forum
GuestDid you updated WCfM and WCfM U both at 3.0.1?
It’s part of WCfM U.
Just to mention, multi element field not yet supported by WCfM for either ACf or Toolset.
It will be part of next update.Thank You
- September 17, 2017 at 4:51 pm #13382
Lourenco.cf
ParticipantSorry,
i can, now see the acf fields file type ! 🙂
thanks!Only not support multi fields is bad… lol
- September 17, 2017 at 7:09 pm #13395
Lourenco.cf
I have one issue
If i insert values in acf custom fields, from vendor dashboard, and submit the product, all values reset to none (0).
Any idea?Any idea for, after submit the product, don´t redirect to the product page? Stay in the dashboard…
- September 17, 2017 at 7:13 pm #13396
Lourenco.cf
ParticipantIt turns out, only if you add the fields manually, in PRODUCT CUSTOM FIELD tab
- September 17, 2017 at 7:53 pm #13420
Shhiv Narayan
So you have also created some Product Custom Field using WCfM Settings as well?
Can you please show us the screenshot of your custom field setting!!
If submitted product published then only it redirect to product page. If in draft then product edit page reopened and for pending go-to product dashboard.
- September 17, 2017 at 8:14 pm #13422
Lourenco.cf
Participant - September 17, 2017 at 10:45 pm #13439
Thanks for the snaps, we understood the issue.
Currently only image/file type fields are saving but not others, Will fix this by next update.WCFM next update will come in 1-2 days.
- September 18, 2017 at 7:02 pm #13473
Lourenco.cf
ParticipantWorks!
In v 3.1.1Thanks!
- September 18, 2017 at 7:12 pm #13476
WCfM Forum
GuestAhh … I am just going to inform you.
But you are faster than me ???? - September 18, 2017 at 7:57 pm #13478
Lourenco.cf
ParticipantAhh…
After, i send you the translator .mo file in pt_PT.You whant them?
- September 18, 2017 at 7:59 pm #13479
WCfM Forum
GuestYeah please. That will be pleasure for me.
Thanks a lot.
- September 19, 2017 at 5:13 am #13497
We are closing this thread for now, kindly send me translation files in mail – wclovers.contact@gmail.com
Thank you very much
Shhiv
- The topic ‘ACF CustomFields integration’ is closed to new replies.
