Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Add costum fields using a CSV file
- This topic has 10 replies, 2 voices, and was last updated 6 years, 9 months ago by
r_guayaquil.
- June 8, 2019 at 10:29 pm #66544
r_guayaquil
Is there a way to add the custom fields information to each product using a csv file? A have a lot of products to uplaod and adding that information one by one in the dashboard is a lot of work.
I added a test product with some custom fields and exported it as cvs files to see which fields i will have to fill in the file to upload the custom fields information at once, but it doesnt show the fields for the custom fields.
How can i do it with the csv file?
Thanks for the help
- June 11, 2019 at 5:04 pm #67016
Custom fields are product meta field, so you upload those using CSV. WC Product Importer support this.
- June 11, 2019 at 7:48 pm #67068
r_guayaquil
I tried to upload the custom fields using meta product field but still doesnt show.
I exported it the csv file with the meta fields, and even de file doesnt show the ones i created. Please see image 1
Image 2 is how i am trying to uplaod the custom field “Precio con envio”
Thank you for the help!
You must be logged in to view attached files. - June 13, 2019 at 7:34 pm #67449
Where it’s not showing ?
- June 13, 2019 at 8:22 pm #67469
r_guayaquil
As i mentioned before i created a new product with the custom fields, and exported it as csv file to see all the fields to upload the information at once.
I am trying filling the csv file with all the product information including the custom fields. I am using the column header as “meta: precio con envio” which is a field i created.
But once i upload the csv file, the custom fields dont show in the product detail page. I have to do it manually one by one.
These are the fields i have created:
Group name: datos_adicionales
Field name:
-Precio_con_envio
-Tiempo_de_entrega
-Formas_de_pago
-Garantía - June 14, 2019 at 9:50 pm #67689
r_guayaquil
i attached the file i exported and dont have the custom field information that i added to the product.
You must be logged in to view attached files. - June 18, 2019 at 11:08 am #68293
Field name:
-Precio_con_envio
-Tiempo_de_entrega
-Formas_de_pago
-Garantía– Do not create custom fields as Group. Keep as simple.
It will be exported.
- June 18, 2019 at 4:31 pm #68416
r_guayaquil
I created the custom fields as simple as you suggested. I created one block that include all the custom fields, and i disabled “Fields as Group” checkbox.
I was able to export the csv file with the meta column header but if i upload it, the custom fields still dont show in the detail product page. Please see image 1
This is what i have:
Block name: Datos Adicionales
Fields as Group: Unchecked
Fields:
Precio_con_envio
Tiempo_de_entrega
Formas_de_pago
GarantíaWhy is that?
Thanks for the help!
You must be logged in to view attached files. - June 21, 2019 at 6:32 pm #68927
Do you have added any value for this product’s custom fields?
https://wclovers.com/wp-content/uploads/2019/06/image-1-2.jpg – First is Block name, what is second? Is this value of any of those 4 custom fields?
Add this line to your child theme’s functions.php if you do not want to show “Block Name” here –
add_filter( 'wcfm_is_allow_custom_field_block_name_display', '__return_false' );Thank you
- June 23, 2019 at 1:25 am #69090
r_guayaquil
ParticipantHi!
I have added values for 2 products. It shows in one product but not in the other one. I exported the csv file again and it seems like the custom fields have repeated themselfs. Please see the file attached and help me fix it.
Now I have to check the “Fields as Group” box if i want the custom fields to show in the product “Proyector Samsung”, If it is not checked they dont show. Please see image 1
This is how i have set it up:
Fields:
Precio_con_envio
Tiempo_de_entrega
Formas_de_pago
GarantíaAttachments:
You must be logged in to view attached files. - June 24, 2019 at 1:14 am #69213
r_guayaquil
I was able to fix it.
- The topic ‘Add costum fields using a CSV file’ is closed to new replies.
