Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Add custom fields
- This topic has 41 replies, 3 voices, and was last updated 6 years, 11 months ago by
- May 30, 2019 at 4:38 pm #65011
r_guayaquil
I just bought the ultimate version. I was trying to add some costum fields reviewing the documentation.
But when i go to add nuew productthis is what i get. image attached.
Also, how can i change the text in the emails a vendor recieves when they register.
Please help!
You must be logged in to view attached files. - May 30, 2019 at 9:17 pm #65062
r_guayaquil
The info doesnt show in the product detail page. Am i doing somwthing wrong? Also, i would like to show the custom fields not only in the product page.
Please see the images attached.
You must be logged in to view attached files. - May 31, 2019 at 8:42 pm #65293
macnomo
ParticipantHola,
intenta nombrar >Agrupar Campos > por ejemplo: precio_final - May 31, 2019 at 8:45 pm #65294
Field Name and Group Name is not right.
Those are only for storing fields in database. Do not use any special character or space in those.
You may specify any type “Label”.
Set names like this – https://ibb.co/Dk1c36k
- May 31, 2019 at 9:33 pm #65314
r_guayaquil
ParticipantThanks for the help!
Is there a way i can show the custom fields in the quick view of the product?
- June 1, 2019 at 9:16 am #65400
It’s possible to show up, but depend upon theme’s quick view template.
Which theme you are using for the site, we will take a look at it!
- June 3, 2019 at 3:39 pm #65755
r_guayaquil
I am using flatsome theme.
- June 4, 2019 at 8:55 am #65831
MemberOK, we will take care of this in next update.
- June 4, 2019 at 3:43 pm #65892
r_guayaquil
Thanks for the help! If it is not too much to ask, can you also make the update to show the custom fields as the image attached.
I would really appreciate it.
You must be logged in to view attached files. - June 5, 2019 at 6:24 pm #66054
Well, we do not want to add this in core.
If you want, I can help you in this.
Between, how many custom fields you have? Do you want to show all of them here!
- June 5, 2019 at 7:00 pm #66084
r_guayaquil
I have in total 4 custom fields, but i only want 2 of them to show there. I would like to show how the image attached looks like.
Also, how can i get rid of the vendors logo in that section?
Thank you so much!
You must be logged in to view attached files. - June 6, 2019 at 6:24 pm #66254
Please add this line of code to your site for the purpose –
add_filter( 'wcfmmp_is_allow_sold_by_logo', '__return_false' );Thank You
- June 7, 2019 at 1:03 am #66325
macnomo
I was about to ask for something similar.
I will like not to show the Field’s name on product page, because we already have a Tag for that field to show, in my case is the shipping methode i want to show and that is like duplicatting the info. Redundan!
Name of field should be only shown/visible to vendor in vendor’s panel, not on product page.
You must be logged in to view attached files. - June 7, 2019 at 2:11 am #66336
r_guayaquil
Thanks for the code!Can you help me showing the 2 custom fields i mentioned?
- June 10, 2019 at 8:47 pm #66837
Please show me your custom fields screenshot and know me which 2 fields you want to show.
- June 11, 2019 at 4:16 pm #67010
r_guayaquil
i attached the screenshot. The 2 fields i want to show are “Precio con envΓo” and “Tiempo de entrega”
Also, as macocifuentes said above, how can i not show the block name of the fields as it is redundant.
You must be logged in to view attached files. - June 13, 2019 at 7:08 pm #67437
Thanks, please send me these two fields names and group name you have added there.
Between, you are using “Flatsome” theme, right?
- June 13, 2019 at 8:14 pm #67468
r_guayaquil
The 2 field names are:
– Precio_con_envio
– Tiempo_de_entregaGroup name:
– datos_adicionalesYes, i am using the flatsome theme.
- June 18, 2019 at 4:36 pm #68420
r_guayaquil
In another topic i started you guys told me not to create custom fields as group but as simple. https://wclovers.com/forums/topic/add-costum-fields-using-a-csv-file/#post-68416
I dont know if thi is going to cause any trouble with you guys helping with the things i need help with mentioned above.
This is what i have:
Block name: Datos Adicionales
Fields as Group: Unchecked
Fields:
Precio_con_envio
Tiempo_de_entrega
Formas_de_pago
GarantΓaThanks you guys for the help!
- June 21, 2019 at 6:33 pm #68928
This setting is fine. I will give you code for this.
Thanks for the details.
- June 22, 2019 at 2:53 am #68985
r_guayaquil
Thanks a lot!
- June 26, 2019 at 1:56 am #69676
r_guayaquil
In the last update did you add the feature to show the custom fields in the quick view?
Also, in the quick view also appears two times the name of the vendor. Please image 1
I am using flatsome.
You must be logged in to view attached files. - June 26, 2019 at 12:32 pm #69733
Please keep custom visibility setting => “Before Product Meta” or “After Product Meta” – https://ibb.co/BB5CF31
It will be visible in Quick View as well.
– We have resolved this in WCFM Marketplace 3.1.1Thank You
- June 26, 2019 at 3:32 pm #69792
r_guayaquil
Thanks for the help!Is there a way i can increase the size of the text in the cutom fields. right now the text es very small.
Also, you helped with a code to hide the logo of the vendor, but can you please help to hide the “Store” text?
You must be logged in to view attached files. - June 26, 2019 at 4:33 pm #69823
Well, you can increase display size easily using CSS. Can you do this, or I will give you CSS for this?
Also, you helped with a code to hide the logo of the vendor, but can you please help to hide the βStoreβ text?
– Add this line –
add_filter( 'wcfmmp_is_allow_sold_by_label', '__return_false' );Thank You
- June 26, 2019 at 4:44 pm #69829
r_guayaquil
Can you please help me with the CSS!
Thanks for everything!
- June 27, 2019 at 4:40 am #69932
You are welcome π
Please use this CSS –
.product-lightbox-inner .product_meta .wcfm_custom_field_display { font-size: 1.3em; }Thank You
- July 1, 2019 at 6:29 pm #70599
r_guayaquil
Please dont forget to help me qith the code.
Thanks π
- July 4, 2019 at 5:37 am #70946
Sorry, code for what ?
Custom fields are already visible at product quick view, right ?
- July 4, 2019 at 3:19 pm #71078
r_guayaquil
Yes, they are visible in the quick view, but you also said you were going to help with a code to show custom fields as image attached.
I have 4 in total but I only want to show 2 custom fields:
Precio_con_envio
Tiempo_de_entregaThanks for the help!
You must be logged in to view attached files. - July 8, 2019 at 6:38 am #71492
MemberPlease give me this page url.
- July 8, 2019 at 7:56 pm #71596
r_guayaquil
What do you mean? You want the url of my website?
- July 13, 2019 at 6:30 am #72230
https://wclovers.com/wp-content/uploads/2019/07/Sin-t%C3%ADtulo.jpg – which page is this? Home page or shop page? I need this page URL.
- July 13, 2019 at 6:30 am #72231
MemberActually, I have to check which element you have used for setting up this page!
- July 14, 2019 at 8:22 pm #72477
r_guayaquil
I want to show in the home page and shop page. Here are the links.
https://www.todomerca.ec/
https://www.todomerca.ec/tienda/Thanks!
- July 16, 2019 at 4:21 pm #72690
Here is your code for the purpose –
add_action('woocommerce_after_shop_loop_item_title', function() { global $WCFM, $WCFMmp, $product; if( !$product ) return; $product_id = $product->get_id(); if( $product_id ) { $wcfm_product_custom_fields = get_option( 'wcfm_product_custom_fields', array() ); if( $wcfm_product_custom_fields && is_array( $wcfm_product_custom_fields ) && !empty( $wcfm_product_custom_fields ) ) { foreach( $wcfm_product_custom_fields as $wpcf_index => $wcfm_product_custom_field ) { if( !isset( $wcfm_product_custom_field['enable'] ) ) continue; $block_name = !empty( $wcfm_product_custom_field['block_name'] ) ? $wcfm_product_custom_field['block_name'] : ''; $wcfm_product_custom_block_fields = $wcfm_product_custom_field['wcfm_product_custom_block_fields']; $display_data = ''; foreach( $wcfm_product_custom_block_fields as $wcfm_product_custom_block_field ) { if( !$wcfm_product_custom_block_field['name'] ) continue; $field_name = $wcfm_product_custom_block_field['name']; if( !in_array( $field_name, array( 'Precio_con_envio', 'Tiempo_de_entrega' ) ) ) continue; $field_value = get_post_meta( $product_id, $field_name, true ); if( $field_value ) { $display_data .= "<label class='wcfm_custom_field_display_label' style='display:inline-block;'>" . wcfm_removeslashes( __( $wcfm_product_custom_block_field['label'], 'wc-frontend-manager') ) . ": </label>"; $display_data .= "<span class='wcfm_custom_field_display_value'>" . $field_value . "</span><br />"; } } if( $display_data ) { echo '<div class="wcfm_custom_field_display wcfm_custom_field_display_'.sanitize_title($block_name).'">'; echo $display_data; echo '</div><div class="wcfm-clearfix"></div><br />'; } } } } }, 45 );Thank You
- July 16, 2019 at 4:51 pm #72695
r_guayaquil
Thanks a lot! You guys are THE BEST π
I dont know how to code and sorry to bother you a lot, but how can i get rid of th space between the custom field “Tiempo de Entrega” and the vendors name?
You must be logged in to view attached files. - July 17, 2019 at 5:52 am #72755
Member - July 17, 2019 at 3:54 pm #72859
r_guayaquil
Thank you! π
- July 18, 2019 at 5:09 am #72917
r_guayaquil
You helped me with the following code to increase the size text of the custom fields in the quick view:
font-size: 1.3em;
}Can you also help me to increase it in the product detail page?
- July 18, 2019 at 5:19 am #72918
r_guayaquil
ParticipantI just figured it out how to do it.
Thanks π
- July 18, 2019 at 12:24 pm #72952
MemberGreat … thanks for the update π
- The topic ‘Add custom fields’ is closed to new replies.
