01Day 23Hr 11Min 51Sec
Add custom fields
Viewing 41 reply threads
    • #65011
      r_guayaquil
      I just bought the ultimate version. I was trying to add some costum fields reviewing the documentation.
      But when i go to add nuew productthis is what i get. image attached.
      Also, how can i change the text in the emails a vendor recieves when they register.
      Please help!
    • #65062
      r_guayaquil
      The info doesnt show in the product detail page. Am i doing somwthing wrong? Also, i would like to show the custom fields not only in the product page.
      Please see the images attached.
    • #65293
      macnomo
      Hola,
      intenta nombrar >Agrupar Campos > por ejemplo: precio_final
    • #65294
      Field Name and Group Name is not right.
      Those are only for storing fields in database. Do not use any special character or space in those.
      You may specify any type “Label”.
      Set names like this – https://ibb.co/Dk1c36k
    • #65314
      r_guayaquil
      Thanks for the help!
      Is there a way i can show the custom fields in the quick view of the product?
    • #65400
      It’s possible to show up, but depend upon theme’s quick view template.
      Which theme you are using for the site, we will take a look at it!
    • #65755
      r_guayaquil
      I am using flatsome theme.
    • #65831
      OK, we will take care of this in next update.
    • #65892
      r_guayaquil
      Thanks for the help! If it is not too much to ask, can you also make the update to show the custom fields as the image attached.
      I would really appreciate it.
    • #66054
      Well, we do not want to add this in core.
      If you want, I can help you in this.
      Between, how many custom fields you have? Do you want to show all of them here!
    • #66084
      r_guayaquil
      I have in total 4 custom fields, but i only want 2 of them to show there. I would like to show how the image attached looks like.
      Also, how can i get rid of the vendors logo in that section?
      Thank you so much!
    • #66254
      Please add this line of code to your site for the purpose –
      add_filter( 'wcfmmp_is_allow_sold_by_logo', '__return_false' );
    • #66325
      macnomo
      I was about to ask for something similar.
      I will like not to show the Field’s name on product page, because we already have a Tag for that field to show, in my case is the shipping methode i want to show and that is like duplicatting the info. Redundan!
      Name of field should be only shown/visible to vendor in vendor’s panel, not on product page.
    • #66336
      r_guayaquil
      Thanks for the code!Can you help me showing the 2 custom fields i mentioned?
    • #66837
      Please show me your custom fields screenshot and know me which 2 fields you want to show.
    • #67010
      r_guayaquil
      i attached the screenshot. The 2 fields i want to show are “Precio con envรญo” and “Tiempo de entrega”
      Also, as macocifuentes said above, how can i not show the block name of the fields as it is redundant.
    • #67437
      Thanks, please send me these two fields names and group name you have added there.
      Between, you are using “Flatsome” theme, right?
    • #67468
      r_guayaquil
      The 2 field names are:
      – Precio_con_envio
      – Tiempo_de_entrega
      Group name:
      – datos_adicionales
      Yes, i am using the flatsome theme.
    • #68420
      r_guayaquil
      In another topic i started you guys told me not to create custom fields as group but as simple. https://wclovers.com/forums/topic/add-costum-fields-using-a-csv-file/#post-68416
      I dont know if thi is going to cause any trouble with you guys helping with the things i need help with mentioned above.
      This is what i have:
      Block name: Datos Adicionales
      Fields as Group: Unchecked
      Fields:
      Precio_con_envio
      Tiempo_de_entrega
      Formas_de_pago
      Garantรญa
      Thanks you guys for the help!
    • #68928
      This setting is fine. I will give you code for this.
      Thanks for the details.
    • #68985
      r_guayaquil
      Thanks a lot!
    • #69676
      r_guayaquil
      In the last update did you add the feature to show the custom fields in the quick view?
      Also, in the quick view also appears two times the name of the vendor. Please image 1
      I am using flatsome.
    • #69733
      Please keep custom visibility setting => “Before Product Meta” or “After Product Meta” – https://ibb.co/BB5CF31
      It will be visible in Quick View as well.
      – We have resolved this in WCFM Marketplace 3.1.1
    • #69792
      r_guayaquil
      Thanks for the help!Is there a way i can increase the size of the text in the cutom fields. right now the text es very small.
      Also, you helped with a code to hide the logo of the vendor, but can you please help to hide the “Store” text?
    • #69823
      Well, you can increase display size easily using CSS. Can you do this, or I will give you CSS for this?
      Also, you helped with a code to hide the logo of the vendor, but can you please help to hide the โ€œStoreโ€ text?
      – Add this line –
      add_filter( 'wcfmmp_is_allow_sold_by_label', '__return_false' );
    • #69829
      r_guayaquil
      Can you please help me with the CSS!
      Thanks for everything!
    • #69932
      You are welcome ๐Ÿ™‚
      Please use this CSS –
      .product-lightbox-inner .product_meta .wcfm_custom_field_display {
          font-size: 1.3em;
    • #70599
      r_guayaquil
      Please dont forget to help me qith the code.
      Thanks ๐Ÿ™‚
    • #70946
      Sorry, code for what ?
      Custom fields are already visible at product quick view, right ?
    • #71078
      r_guayaquil
      Yes, they are visible in the quick view, but you also said you were going to help with a code to show custom fields as image attached.
      I have 4 in total but I only want to show 2 custom fields:
      Precio_con_envio
      Tiempo_de_entrega
    • #71492
      Please give me this page url.
    • #71596
      r_guayaquil
      What do you mean? You want the url of my website?
    • #72230
      https://wclovers.com/wp-content/uploads/2019/07/Sin-t%C3%ADtulo.jpg – which page is this? Home page or shop page? I need this page URL.
    • #72231
      Actually, I have to check which element you have used for setting up this page!
    • #72477
      r_guayaquil
      I want to show in the home page and shop page. Here are the links.
      https://www.todomerca.ec/
      https://www.todomerca.ec/tienda/
    • #72690
      Here is your code for the purpose –
      add_action('woocommerce_after_shop_loop_item_title', function() {
      	global $WCFM, $WCFMmp, $product;
      	if( !$product ) return;
      	$product_id = $product->get_id();
      	if( $product_id ) {
      		$wcfm_product_custom_fields = get_option( 'wcfm_product_custom_fields', array() );
      		if( $wcfm_product_custom_fields && is_array( $wcfm_product_custom_fields ) && !empty( $wcfm_product_custom_fields ) ) {
      			foreach( $wcfm_product_custom_fields as $wpcf_index => $wcfm_product_custom_field ) {
      				if( !isset( $wcfm_product_custom_field['enable'] ) ) continue;
      				$block_name = !empty( $wcfm_product_custom_field['block_name'] ) ? $wcfm_product_custom_field['block_name'] : '';
      				$wcfm_product_custom_block_fields = $wcfm_product_custom_field['wcfm_product_custom_block_fields'];
      				$display_data = '';
      				foreach( $wcfm_product_custom_block_fields as $wcfm_product_custom_block_field ) {
      					if( !$wcfm_product_custom_block_field['name'] ) continue;
      					$field_name = $wcfm_product_custom_block_field['name'];
      					if( !in_array( $field_name, array( 'Precio_con_envio', 'Tiempo_de_entrega' ) ) ) continue;
      					$field_value = get_post_meta( $product_id, $field_name, true );
      					if( $field_value ) {
      						$display_data .= "<label class='wcfm_custom_field_display_label' style='display:inline-block;'>" . wcfm_removeslashes( __( $wcfm_product_custom_block_field['label'], 'wc-frontend-manager') ) . ":&nbsp;</label>";
      						$display_data .= "<span class='wcfm_custom_field_display_value'>" . $field_value . "</span><br />";
      				if( $display_data ) {
      					echo '<div class="wcfm_custom_field_display wcfm_custom_field_display_'.sanitize_title($block_name).'">';
      					echo $display_data;
      					echo '</div><div class="wcfm-clearfix"></div><br />';
      }, 45 );
    • #72695
      r_guayaquil
      Thanks a lot! You guys are THE BEST ๐Ÿ™‚
      I dont know how to code and sorry to bother you a lot, but how can i get rid of th space between the custom field “Tiempo de Entrega” and the vendors name?
    • #72755
      Please remove this last “br” from the code – https://ibb.co/Y7pfDz0
    • #72859
      r_guayaquil
      Thank you! ๐Ÿ™‚
    • #72917
      r_guayaquil
      You helped me with the following code to increase the size text of the custom fields in the quick view:
      font-size: 1.3em;
      Can you also help me to increase it in the product detail page?
    • #72918
      r_guayaquil
      I just figured it out how to do it.
      Thanks ๐Ÿ™‚
    • #72952
      Great … thanks for the update ๐Ÿ™‚
