Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Add custom menu entry plus content
- This topic has 4 replies, 2 voices, and was last updated 6 years, 7 months ago by
- January 5, 2019 at 9:29 am #42290
andreasenglowski
ParticipantHi, i want to extend the dashboard by adding two more menu entries if possible. On entry is very simple and its content is just some html with a few navigation links.
The second is bit more tricky but maybe you have a idea: i am also using affiliate plugin (affiliatewp) and it would be great to integrate in the vendor dashboard for vendors which are also affiliates. Is that possible?
Many thanks in advance,
AndiAttachments:
You must be logged in to view attached files. - January 5, 2019 at 11:07 am #42301
Please get help from this custom addon – https://drive.google.com/file/d/1FHPiyEYCi78qapaYHSIcmHq3ilordR6G/view?usp=sharing
- January 5, 2019 at 11:23 am #42304
andreasenglowski
ParticipantThank you, will check it out now =)
- January 5, 2019 at 12:07 pm #42314
andreasenglowski
ParticipantYeah thats great everything working, awesome! Just one more little thing: how can i set the position of the menu entries? At the moment they are coming after bookings section but i want them to be at the end of the list before the LogOut and Settings entries.
- January 5, 2019 at 12:19 pm #42316
Kindly go to WCFM Admin Setting -> Menu Manager
Hopefully, you have all these new menus there as well. Change position.
Or, off course change from code as well. Have to change there menu priority (https://ibb.co/yFPZgW2)
- The topic ‘Add custom menu entry plus content’ is closed to new replies.
