Add extra section on vendor store page or show about info above product listings
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Marketplace Add extra section on vendor store page or show about info above product listings
Viewing 1 reply thread
    • #102135
      Sarah
      Is it possible to add extra sections on the vendor store page? I would like to show the About Text prominently for each store above the Tabs rather than have a tab for it?
      Also, is it possible to add a field for website under the email address of each vendor on the vendor store pages? Thank you.
    • #106042
      Please add this code to your site for the purpose-
      add_filter( 'wcfmmp_store_tabs', function( $store_tabs, $store_id ) {
      	if( isset( $store_tabs['about'] ) ) unset( $store_tabs['about'] );
      	return $store_tabs;
      }, 50, 2 );
      add_action( 'wcfmmp_before_store_product', function( $store_id, $store_info ) {
      	$store_user   = wcfmmp_get_store( $store_id );
      	$wcfm_shop_description = apply_filters( 'wcfmmp_store_about', apply_filters( 'woocommerce_short_description', $store_user->get_shop_description() ), $store_user->get_shop_description() );
      	if( $wcfm_shop_description ) { ?>
      		<div class="wcfm-store-about">
      			<div class="wcfm_store_description" ><?php echo $wcfm_shop_description; ?></div>
      		</div>
      	<?php }
      }, 50, 2 );
  • The topic ‘Add extra section on vendor store page or show about info above product listings’ is closed to new replies.
