Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Add product bottom page is cut off when you add more than one picture
- This topic has 7 replies, 3 voices, and was last updated 5 years, 6 months ago by
Sarmistha Chakraborty.
- December 14, 2019 at 4:43 am #97404
rorylsoto
ParticipantHi, so as the title states whenever a vendor is adding a new product, and an extra picture is added, the bottom settings are cut off. This is only viewable in the store policy tab or if there are custom fields. It hides the bottom policy in such a way as you can’t scroll down and access it. Is there a fix available for this? or something you could suggest to change in the settings to fix it.
- December 24, 2019 at 10:38 am #98883
Can you please show me screenshot for this?
Between, which theme you are using for the site?
- January 3, 2020 at 9:08 pm #100744
- January 25, 2020 at 11:20 pm #103850
rorylsoto
ParticipantAny suggestions?
- January 28, 2020 at 5:18 pm #104391
jQuery(document).ready( function($) { $('#wcfm_products_manage_form .wcfm-tabWrap').css('height',$('#wcfm_products_manage_form .page_collapsible.collapse-open').next().height()); });
Add this code to your child theme’s JS (javasript) file.
In case you do not have child theme then add code using this plugin – https://wordpress.org/plugins/header-and-footer-scripts/ (https://www.ostraining.com/blog/wordpress/custom-js/)Thanks.
- January 28, 2020 at 8:32 pm #104408
rorylsoto
ParticipantThank you I will give this a try.
- February 5, 2020 at 1:36 am #105457
rorylsoto
ParticipantUnfortunately this did not work for me. Are there any other options available?
- February 5, 2020 at 11:42 am #105506
Kindly share your siteurl with access details here : https://wclovers.com/woocommerce-multivendor-customization/ (with this topic link), then we can your site.
- The topic ‘Add product bottom page is cut off when you add more than one picture’ is closed to new replies.
