Add Product Designer Compatibility
Viewing 4 reply threads
    • #55122
      Andrew from Great Lakes Made
      Found this product designer and saw that it was Dokan compatible: https://codecanyon.net/item/fancy-product-designer-woocommercewordpress/6318393?s_rank=1
      Can you make this compatible for vendors?
    • #55125
      Craig
      I vote that that integration too!
      BUT it does look like it is a complicated (so many variables) plugin.
    • #55225
      WCFM Ultimate already has this compatibility.
      Please check this – https://www.useloom.com/share/112c4a32486a418593a0bc20e781275b
    • #57996
      Haisam
      I have a version WCFM Ultimate Version 6.0.2
      What version is Fancy Designer compatible with WCFM Ultimate
      I have a version
      WooCommerce Frontend Manager
      WCFM Ultimate
      WooCommerce is really Easy and Beautiful. We are here to make your life much more Easier and Peaceful.
      Version 6.0.2
    • #58000
      Craig
      Awesome!!! thanks for this information.
  • The topic ‘Add Product Designer Compatibility’ is closed to new replies.
