Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Ultimate › Add Product | Downloadable
- This topic has 5 replies, 2 voices, and was last updated 6 years, 6 months ago by
- September 8, 2018 at 4:07 pm #31165
wwsAdmin
ParticipantHello Team,
Can you explain what is solution ? https://wclovers.com/forums/topic/add-product-downloadable/.
As i can see File URl “Downloadable file is required.” is only message.
As i mentioned if URL is given but no File name. link is not coming in Review.
Can make File Name also mandatory like File URL and show some message if it is empty ?
- September 11, 2018 at 8:38 am #31301
But both the fields are required and validation is there – https://ibb.co/jOhOkU
Hope you are using latest WCFM and no custom code or template override is there related to this!
- September 11, 2018 at 12:11 pm #31337
wwsAdmin
ParticipantHello team,
Maybe due to template override ot might be impacting. Will do it.
- September 11, 2018 at 2:56 pm #31349
In that case send me that override template and I will add this restriction over there.
- September 11, 2018 at 4:05 pm #31362
wwsAdmin
ParticipantHi team,
I wi try to override my changes using latest template. If not possible then will send it to you.
Thanks for extended help. 🙂
Cheers 🤗
- September 11, 2018 at 4:55 pm #31368
MemberThat’s fine.
You are welcome 🙂
- The topic ‘Add Product | Downloadable’ is closed to new replies.
