Add-Product-Form (Make Taxonomies required)
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Add-Product-Form (Make Taxonomies required)
Viewing 5 reply threads
    • #38218
      Hoody
      1. Add-Product-Form: Is there a way to mark Taxonomies associated with a product as “required” fields in the add product vendor form (Would be nice if you could ad that with the next update)
      2. Right now product taxonomies are text-Input fields and the vendor has to type the different taxonomies (separated by “,”) – but an new vendor doesnt know hat to type in -> it would be helpfull if the Vendor could see the different possibilities of each Taxonomie, maybe in somekind of dropdwon oder with check-boxes (like it already works with product categories). -> Choosing Taxonomies as a vendor should be the same way like choosing a product category.
    • #38279
      Please check this – https://ibb.co/wsBPPhc
      WCFM already has this option but this comes with WCFM Ultimate.
      “Right now product taxonomies are text-Input fields and the vendor has to type the different taxonomies”
      But, why this? Do you have created custom taxonomies?
    • #38368
      Hoody
      1. I have the Ultimate-Version but its not possible for taxonomies to be marked as required (only Categories /Tags). Please take a look at the Screenshot ( https://prnt.sc/lnpgez )
      2. Also Explained in the screenshot
    • #38458
      You have created custom taxonomies, right?
      There has some thing wrong in code, you have to define those custom taxonomies as “hierarchical”!
      This will resolve your both the issues – Taxonomy as Text input and define them as required.
    • #38553
      Hoody
      Great! Thank you very much! 🙂 Indeed your answer solved both of may problems!
      I sill have one question: Can I change the order of the Taxonomnies for the Vendor? -> Scrennshot: https://prnt.sc/lo5inj
      Thank you! 🙂
    • #38588
      That’s fantastic 🙂
      “I sill have one question: Can I change the order of the Taxonomnies for the Vendor?”
      – Umm … I think no, this display generate as per these taxonomies were registered at WP. I am not sure is this order can be toggle anyway or not!
  • The topic ‘Add-Product-Form (Make Taxonomies required)’ is closed to new replies.
