Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Add product form – view subcategories
- This topic has 1 reply, 2 voices, and was last updated 6 years, 11 months ago by
Viewing 1 reply thread
- September 19, 2019 at 3:36 am #82359
aurelien_boutillier
In the add product form, the vendor can see the categories to fill in but he has to click on the arrow to see the subcategories and then check the box (images attached).
I would like to display directly the categories and subcategories (the seller no longer needs to click on the arrow) (image attached)
Do you know if it’s possible ?
Best regards
Aurélien.Attachments:
You must be logged in to view attached files. - September 21, 2019 at 8:04 pm #82811
add_action( 'after_wcfm_products_manage', function() { ?> <script> jQuery(document).ready(function($) { setTimeout(function() { $('#product_cats_checklist').children('.product_cats_checklist_item').each(function() { if( $(this).children('.product_taxonomy_sub_checklist').length > 0 ) { $(this).children('.sub_checklist_toggler').click(); } }); }, 1000); }); </script> <?php }, 50 );Add this code to your child theme’s functions.php
- The topic ‘Add product form – view subcategories’ is closed to new replies.
