Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Add Product | Variable | Manage Stock
- This topic has 17 replies, 2 voices, and was last updated 8 years, 1 month ago by
- September 26, 2018 at 7:17 pm #32629
wwsAdmin
ParticipantHello team,
Manage stock is not working for variation product. Product is showing out of stock.
I have tested 3 scenarios only 1 works.
As soon as i enable stock manage it goes out of stock.Scenario 1:
enabled stock under inventory as well as variation img attached. still out of stockAttachments:
You must be logged in to view attached files. - September 26, 2018 at 7:21 pm #32633
wwsAdmin
ParticipantScenario 2:
Under inventory stock status “in stock”, but enabled stock under variation.
After submit Under inventory stock status changes to “out of stock”. on product same out of stock. Image attachedScenario 3:
stock status “in stock” under inventory as well as variation <= This works and product i can but. can you check ?
You must be logged in to view attached files. - September 27, 2018 at 3:01 pm #32697
I am checking this.
Thanks for all the details.
- September 28, 2018 at 3:18 am #32745
wwsAdmin
Yes please do check it 🙂
- September 29, 2018 at 4:58 am #32820
I have tried this many way but unable to generate.
Can you please try once here – http://wcfmmp.wcfmdemos.com/my-account
Between, are you using any other Stock manager plugin for WC?
- September 29, 2018 at 5:01 am #32821
wwsAdmin
ParticipantHI,
I will try to recreate same thing on link given by you.
No stock manager plugin is used.
I will grant you temp admin access if needed.
- September 29, 2018 at 5:35 am #32825
Give me a test vendor account first.
- September 29, 2018 at 5:45 am #32828
wwsAdmin
ParticipantThis reply has been marked as private. - September 29, 2018 at 6:50 am #32831
wwsAdmin
ParticipantThis reply has been marked as private. - October 1, 2018 at 5:58 am #32947
wwsAdmin
ParticipantHi team,
Did you got time to have look in it ?
- October 1, 2018 at 7:12 am #32955
MemberSorry, I will check this today.
- October 1, 2018 at 10:41 am #32967
wwsAdmin
ParticipantNo problem 🙂
- October 3, 2018 at 5:41 pm #33219
wwsAdmin
ParticipantHi team,
Any update ? can u replicate ?
- October 4, 2018 at 8:33 am #33250
I was debugging this and found that problem is at here – https://ibb.co/hoQLKK
Once this product become “Out of Stock” but it’s not back to “In stock” when adding stock to this.
Now, this is not normal for default WC, do you have any other stock related plugins?
Between, what is your WC Stock Setting – https://ibb.co/fiRGte
- October 4, 2018 at 6:59 pm #33305
wwsAdmin
I guess WC Stock Setting – https://ibb.co/fiRGte was culprit sorry for troubling you 🙁
i have changed back to 0 it was set to 1 earlier.
Have asked vendor to test lets see
- October 6, 2018 at 5:33 am #33383
MemberOk sure, no problem.
Please test and know me.
- October 6, 2018 at 6:45 am #33389
wwsAdmin
I have tested. its working.
- October 6, 2018 at 7:07 am #33392
MemberThat’s awesome 🙂
- The topic ‘Add Product | Variable | Manage Stock’ is closed to new replies.
