Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Add to cart Button Missing
- This topic has 1 reply, 2 voices, and was last updated 5 years, 4 months ago by
Sarmistha Chakraborty.
- May 1, 2020 at 11:45 pm #125542
ghumighumi1
Participanthello,
I just started using your plugin and its great plugin. but I found an issue in my vendor’s product list the add to cart button is missing, if we want to add a product from a vendor then we must open that product and then add it to the cart, I just need to add to cart button on the vendor’s product list page, so the user easily adds their favorite products to cart.
here is the link so you can easily found what’s wrong here:- https://pickacho.in/store/wholesale-kiryana-store/is there any setting that I miss to set or anything else is wrong.
please help me to solve this issue.
- May 3, 2020 at 1:56 pm #125970
In our WCFM plugin, The product blocks in vendor’s store page(https://pickacho.in/store/wholesale-kiryana-store/) is same as WooCommerce shop page (https://pickacho.in/shop/)
To modify product blocks, you need to modify WooCommerce product blocks in shop page.
Please contact with your theme support how to display cart button in WooCommerce shop page(https://pickacho.in/shop/), then it will reflect vendor’s store page(https://pickacho.in/store/wholesale-kiryana-store/).Thanks.
