add to cart error message
Viewing 1 reply thread
    • #106307
      wouloresto
      Dear WC Lovers,
      I struggle with a problem on my store.
      I can’t add to cart more than 1 product (with attribute) from the same vendor.
      Example:
      If I try to add more than one product with attribute to the cart I have this message:
      Well, you already have some item in your cart. First checkout with those and then purchase other items!”
      The problem is that: The product are from the same vendor.
      Thank you. I hope you will be able to help me
    • #106834
      Keymaster
      Thanks for getting in touch and sorry for any inconvenience caused.
      The problem seems to be happening for some other reasons. Could you please check if one or both the products are marked as “Sold Individually”. You can find that setting under ‘Inventory’ tab in add/edit product page.
      Let me know how it goes.
  • The topic ‘add to cart error message’ is closed to new replies.
