Adding product from frontend not working
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Membership Adding product from frontend not working
Viewing 11 reply threads
    • #44462
      JulienCKJM
      Hi, the function of adding products from the frontend manager is not working for the admin as well as for any other vendor. When clincking on submit, a red message appear saying “add the title of the product” even after the product’s title is already added. How to fix this?
    • #44463
      Are you using GEO my WP?
      If yes, can you disable this and check once!
    • #44464
      JulienCKJM
      Now it’s saying
      “Name: This field is required
      file: This field required”
      Then I disabled Geo my WP, and it’s still showing those two messages
    • #44465
      Possibly you are trying to create “Downloadable” product.
      So, downloadable file name and file is essential to add. Check under Downloadable tab
    • #44466
      JulienCKJM
      Not at all, I haven’t selected downloadable product
      But now I’m able to add the product from the admin frontend only, not yet from the vendor frontend, and I haven’t changed anything yet, it’s acting weird
    • #44467
      JulienCKJM
      Hey now everything restarts working fine, again I didn’t anything at all, it just fixed itself just like that, have no idea what is going on
    • #44468
      JulienCKJM
      But Geo my WP is still disabled! Shall I keep it that way or is it safe now to reactivate it now?
    • #44479
      Please keep disable till WCFM next update.
      DO you have WCFM Ultimate? Then please check at WCFM Admin Setting -> Product Custom Validation options?
    • #44483
      JulienCKJM
      I do have Ultimate. But as of now, everything seems to work normal, the problem hasn’t occured so far. If it shows up again, I’ll notify you. And I’ll keep Geo my WP deactivated till the update greenlight. Thank you again
    • #44498
      WCFM new version (5.3.1) has just released.
      Kindly update this and also activate GEO my WP.
    • #44499
      JulienCKJM
      Wow that was fast, love it!!
      Thank you again
    • #44500
      You are welcome 🙂
  • The topic ‘Adding product from frontend not working’ is closed to new replies.
