Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Adding translation
- This topic has 4 replies, 4 voices, and was last updated 7 years, 10 months ago by
Shhiv Narayan.
- October 24, 2017 at 5:59 pm #14759
Charlie
GuestHello,
I just translated WCFM in French and I wanted to know if there is a way to put it in my child theme files.
The purpose is to keep my translation when the plugin is updated. - October 24, 2017 at 7:19 pm #14760
WC Lovers Forum
How you have translated the plugin? Using Loco Translate or something else?
Why you are not share those translation with us? We will make those part of WCFM core and this there will no issue with the updates.
Please know your thoughts.
Shhiv - October 25, 2017 at 8:54 am #14785
charlie.bourguignat
ParticipantThis reply has been marked as private. - October 25, 2017 at 1:45 pm #14812
Shhiv Narayan
Really really thanks for the sharing.
And it’s really awesome as mentioned that.
We will chnage that ourself.
Thank you very much.
Shhiv
- October 27, 2017 at 6:33 pm #14894
Shhiv Narayan
Do you have exposer of Loco Translate?
Please install the plugin and start translating using this and choose system location. Now this will create folder for you under plugins directory, just place your translated files there.
If you are not getting me clearly please know me, I will send you a help video for that.
Please don’t translate again using this as you have already did that.
- The topic ‘Adding translation’ is closed to new replies.
