Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Additional fields for product management
- This topic has 5 replies, 2 voices, and was last updated 8 years ago by
WCfM Forum.
- June 5, 2017 at 11:20 am #10316
Hassan A
GuestHello,
I am using a plugin to set estimated dispatch date for products, it adds a field in the wp-admin page where each product can have no. of days needed to be dispatched… How can I reflect this field and show it in the Product Management page for the vendors to be able to set for their products?
Hassan - June 5, 2017 at 11:56 am #10317
MemberHi Hasan,
Kindly share the name of the Plugin.
If its relevant enough then we will directly integrate it with WCFM core, otherwise guide you how to integrate third party addons with WCFM Product manager using hook-filter.Thank You
- June 5, 2017 at 12:48 pm #10323
Hassan A
GuestThis is the plugin:
WooCommerce – Estimated Dispatch Dateyou can find it here:
https://codecanyon.net/item/woocommerce-estimated-dispatch-date/15865347Many Thanks for your support,
Hassan - June 5, 2017 at 2:09 pm #10325
MemberHi Hasan,
Thanks for the information but I am sorry to say that we can not integrate any “codecanyon” addon into WCFM core module.
Still we can help you in this case, we will send a code snippet how to integrate addon plugins into WCFM product manager, hope this will helpful for you.
Other alternate solution is that, we can do that exclusively only for you, but that will be paid customization. If you want that then please contact us with further details at wclovers.contact@gmail.com
Shhiv Narayan
Support WCfM - June 7, 2017 at 9:57 am #10404
Hassan A
GuestThanks,
I will email you for the integration part.
Thx,
H - June 7, 2017 at 10:05 am #10405
WCfM Forum
GuestYeah sure.
- The topic ‘Additional fields for product management’ is closed to new replies.
