wcfm-santa
-363Day -4Hr -6Min -29Sec
wcfm-santa
Additional Info tab
Viewing 9 reply threads
    • #53018
      paul1
      My theme has one Additional information tab on product listing display, but there is no way to populate this from frontend dashboard, only from backend. How to change this?
    • #53067
      What it shows?
      Which theme you are using?
    • #53092
      paul1
      Theme is Porto.
      At the moment the tab only shows the attributes/variables – example: https://burnley.lancs.life/product/venicci-soft-travel-system-open-basket/
    • #53098
      Well, WooCommerce by default shows this tab under single product page.
      Is there any special setting in your theme to enable this? Please show me screenshot for this!
    • #53099
      paul1
      Screenshot attached
    • #53126
      This is theme global setting. Just enable that from here and it will applicable to all products!
    • #53159
      paul1
      Ok, I think I have not been clear. The additional tabs are generated by a plugin – the theme only displays the tabs. The plugin can be found here: https://wordpress.org/plugins/yikes-inc-easy-custom-woocommerce-product-tabs/
      I have attached a screenshot of what the backend of ‘add a product’ looks like on my site and highlighted the ‘additional tabs’ – it is this ‘additional tabs’ that I would like to be available on the frontend vendor dashboard.
    • #53221
      OK, you told me theme option so I was confused!
      Well, WCFM only compatible with this tab manager plugin – https://woocommerce.com/products/woocommerce-tab-manager/
    • #53243
      paul1
      Thanks – that works great
    • #53246
      Great … you are welcome 🙂
  • The topic ‘Additional Info tab’ is closed to new replies.
