Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM › Additional product categories or specific details
- This topic has 23 replies, 2 voices, and was last updated 7 years, 4 months ago by WCFM Forum.
- August 22, 2017 at 11:26 am #12262KatieGuest
Hi again.
Would “ultimate” be able to provide additional product specifics for store owners to add.
eg: using vendors product page to display
by store
Categories: Craft, Gift
Count: 120
Type: PDF trace
Grade: Pre primeretc
- August 22, 2017 at 12:22 pm #12263WCfM ForumGuest
Welcome back ????
How are you and how is your everything going on ?First tell me onething, Grade – Type – count
What these will be in your system ?
If these are Product Custom Taxonomies then you will definite able to assign them with Product usng WCfM, even with free no Ultimate required!!But for showing Vendor stores or product depending upon selection is not part of WCfM.
That’s totally depending upon theme template or may be control by any plugin.
If you are planning to use such things as Product Custom Taxonomy then I will suggest you to use ToolSet Plugin. You will have some template options over their as well.
- August 23, 2017 at 5:59 am #12271KatieGuest
Thanks again .
Yes they are custom fields for products.
Currently using https://wordpress.org/plugins/wc-fields-factory/
Which allows what I need (almost) only it does not display in the Front end manager unless (user input options are chosen)
Don’t want those, want only admin side options but cannot get them to appear in the product creation section of your great plugin.Was looking at this – seems I will need ultimate anyways as we all use downloadable products. Just not quite ready for it yet as ironing out the last functionality required.
WCfM will give you the super power of Custom Field. You don’t need to write any code even, just create custom fields to integrate your WC addons in most easiest way ever. - August 23, 2017 at 6:38 pm #12286WCfM ForumGuest
We will try our best to support this plugin as well in very near future version.
Just a bit confuse with your requirement-
Do you want those custom fields will only be available to Admin but not to the Vendors !!Thank You
- August 24, 2017 at 1:11 am #12287KatieGuest
Sorry – fields for admin side for vendors (ie not an entry field for buyers, which are what the fields produce that are visible in the Front end manager and on the product front end view itself.)
When using the Admin fields (available in the plugin) these do not show on the Front end Manager (my new very favourite plugin) nor on the product front end view.Meanwhile I will have a look at the Toolset
- August 24, 2017 at 8:15 am #12306WCfM ForumGuest
Now I understand that clearly.
Off course those fields are not visible in Frontend Paroduct Manager as WCfM is not yet compatible with that.But still I want to mention something, WCfM will make that conpatible to bring thise fields in Product Manager but in product view page how those will come !!
This is not part of WCfM, this can be achieve only by over-riding WC templates under child-theme.Please check ToolSet, I am sure you will love this.
Please know your thoughts …
- August 24, 2017 at 9:24 am #12309KatieGuest
Yes thanks am just looking over toolset and it does the same – so I will implement it and test it out.
Understand re template, and working through options
The Fields factory displays front end on the product page without any coding or php – just not where it should.
Will work through and get back to you .
Thanks so much for all your time and assistance. - August 24, 2017 at 11:45 am #12310WCfM ForumGuest
Yeah sure.
Thanks for your cooperation as well.
- August 26, 2017 at 5:06 am #12344KatieGuest
Testing options in toolset.
added taxonomy – chose “flat” to allow store owners to add data to that taxonomy (these will be individual entries not chosen from a selection)
Works in the standard product dashboard – adding that taxonomy with an entry.
However using WCFM that taxonomy will not accept entries – default text displays “choose resource-size” rather than allow an entry.product taxonomy – Resource Type
- August 26, 2017 at 3:59 pm #12368WCFM ForumMember
I think there has some misunderstanding so I prefer to repeat the same steps for you.
Kindly check the attached video, I have recorded all those for you and confirm if I missed anything.Thanks for your patience …
- August 27, 2017 at 12:48 am #12386KatieGuestThis reply has been marked as private.
- August 27, 2017 at 12:34 pm #12398WCFM ForumMember
WCfM 3.0 has just released.
It’s already has supported this feature, kindly update yours and Check.If you have any further issues feel free to share with us.
- August 28, 2017 at 1:01 am #12403KatieGuest
Thanks so much again – the tags now function as expected.
Please note now getting: When loading products in the dashboardjquery.dataTables.min.js:27 Uncaught TypeError: Cannot set property ‘nTf’ of undefined
at mb (jquery.dataTables.min.js:27)
at ha (jquery.dataTables.min.js:48)
at e (jquery.dataTables.min.js:93)
at HTMLTableElement.<anonymous> (jquery.dataTables.min.js:93)
at Function.each (jquery.js:2)
at a.fn.init.each (jquery.js:2)
at a.fn.init.m [as dataTable] (jquery.dataTables.min.js:82)
at a.fn.init.h.fn.DataTable (jquery.dataTables.min.js:167)
at HTMLDocument.<anonymous> (wcfm-script-products.js:6)
at i (jquery.js:2) - August 28, 2017 at 3:04 am #12404WCFM ForumMember
Kindly clear browser cache and check.
If your site has some caching then please clear for WCfM dashboard page.Thank You
- August 28, 2017 at 6:41 am #12406KatieGuest
I always clear cache – but its an uncaught error –
- August 28, 2017 at 8:05 am #12407WCfM ForumGuest
We have checked things in depth but there is no such issues.
You may even check any of our demos.
Can you please check the same in any other Browser once !!
If you still having the same issue then only if comfortable enough to debug the things by us please share your site access in email.
May be some Plugin or theme conflict, but I think it’s not in your case as things was working properly.
Thank e
- August 28, 2017 at 9:13 am #12412KatieGuest
HI again thanks – As I do 3 browsers clear cache flush dns.
you have the login details I have left them open for you. - August 28, 2017 at 9:25 am #12413WCFM ForumMember
Ahh .. sure.
I am just looking into it.Thank You
- August 28, 2017 at 9:39 am #12414WCFM ForumMember
It just loaded perfect for me.
Kindly check the attached video.I am not sure about the test user access I have !!
Are you getting that error as Vendor User Or Admin user or for both?Thank You
You must be logged in to view attached files. - August 29, 2017 at 3:46 am #12464WCFM ForumMember
Is this now working for you?
Any updates!!Thank You
- August 29, 2017 at 7:35 am #12475KatieGuest
Not yet. Sometimes the responses from here don’t come through and only just seeing this now as I was checking.
Admin – but I have deactivated Front end for the moment and will let you know when I reactivate it, what happens.
There is no caching but maybe server side varnish – unsure, doing some testing. - August 29, 2017 at 7:40 am #12476WCfM ForumGuest
Yeah sure, that’s absolutly fine.
Take your time and test the things in your way.
Feel free to reach us anytime.
- August 30, 2017 at 1:20 am #12522KatieGuestThis reply has been marked as private.
- August 30, 2017 at 4:34 am #12523WCFM ForumMember
That’s something really surprising!!
Hope no more such issues will be there in future.You may upgrade your WCFM anytime you preferred and really thanks for the Grammar corrections.
- The topic ‘Additional product categories or specific details’ is closed to new replies.
