Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Advanced Custom Fields
- This topic has 7 replies, 2 voices, and was last updated 7 years, 5 months ago by
- January 3, 2018 at 6:09 am #17507
Eddy Trivulce
Happy New Year
I use ACF and I think there is a little bug.
I use a check box with the option to disable affiliate earnings for products on sale.
It works fine but the problem is that the box is then unchecked by default so I can not change the option anymore.
I have tried since the Back end and it works properly.
Could you look at this please?I can give you access to the site if you wish.
Kind Regards
Eddy
- January 4, 2018 at 8:13 am #17540
Happy New Year!
Kindly send me access of your site here – https://wclovers.com/contact-us/
If there is any such issues, we will definitely resolve for you.
Simha - January 5, 2018 at 1:52 pm #17583
Eddy Trivulce
Thanks for your answer but there are several things that do not work as I would like on my site with WCFM. there is ACF, some translations, the shipping classes are not configurable by the seller and the addition of product with a sale price without initial price does not display the add to cart button, I look at the configuration of my site and maybe it’s a misconfiguration on my part but I have searched, I can not find where it comes from.
I see if there are other things to report and I send you access to the site.
Kind Regards
Eddy
- January 5, 2018 at 2:15 pm #17587
Let me clear your doubts –
1. there is ACF – I have to check this (Between, what you are using ACF or ACF Pro?)
2. some translations – Kindly sync your translation file with latest WCFM (which tool you are using for translation?)
3. the shipping classes are not configurable by the seller – There is no multi-vendor plugin which allow this for vendors. (which multi-vendor plugin you have installed?)
4. product with a sale price without initial price does not display the add to cart button – this is WooCommerce default feature, without “Regular Price” there is no value of “Sale Price” so no “Add to Cart” button. There is no configuration for that.Please know me if you have any further doubts.
Simha - January 5, 2018 at 2:34 pm #17589
Eddy Trivulce
1. I use the free ACF version and it works well in the Back end
2. I use loco translate and i have already sync the translation
3. I use WC Marketplace and before buying WCFM which is great and better I bought their front end extension and sellers could set the price for their delivery class.
4. Ok i don’t know thisI send you the access to the site
Eddy
- January 6, 2018 at 9:07 am #17604
MemberHi
– It is resolved, kindly take a look2. I use loco translate and i have already sync the translation
– WCFM Free was not synced, I just did that.3. I use WC Marketplace and before buying WCFM which is great and better I bought their front end extension and sellers could set the price for their delivery class.
– Kindly check our demo once, http://wcmp.wcfmdemos.com/my-account
Check vendors shipping settings, is your vendors missing this? Please confirm me this, then I will check as vendor, it’s probably configuration issue.4. Ok i don’t know this
– Not an issue.Thank You
Shhiv - January 6, 2018 at 1:42 pm #17610
Eddy Trivulce
Thank You very Much
Very Good support
Kind Regards
Eddy
- January 7, 2018 at 6:29 am #17613
MemberWelcome 🙂
We are closing this thread for now.
Feel free to reach us anytime.
- The topic ‘Advanced Custom Fields’ is closed to new replies.
