Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Affiliate › Affiliate Feature Suggestions
- This topic has 2 replies, 3 voices, and was last updated 5 years, 8 months ago by
yogeshsharma85.
- December 11, 2019 at 4:57 am #96974
id.manage
ParticipantHi Guys,
I am using affiliate addon. It would be great to have more features
1) different product/category can have different commission ( I remember you mentioned it would have the feature later?)
2) more detailed information about the affliate commssion —which product has lead the commission, which order matches the commission.Thank you for the great job!
- December 12, 2019 at 5:07 pm #97228
– We will add product wise affiliate commission setting option in next update.2) more detailed information about the affliate commssion —which product has lead the commission, which order matches the commission.
– Sure, will do so.Thank You
- January 1, 2020 at 1:19 pm #100351
yogeshsharma85
ParticipantI am using affiliate addon on my site, but this plugin is missing so many core functionalities such as – When an affiliate register and waiting for approval, there’s no such option in the affiliate section to approve the affiliate. We need to go to the Notification Board area to check and from there we approve. Our website is very big and this is a must feature as we get so many notifications so we couldn’t check complete affiliate requests and we’re losing many affiliates because of this.
There should be an option like vendors, where we can see the pending vendors and from there onwards we can approve or disapprove the affiliates instead of going into notification area.
2). I added some custom fields registration fields for affiliate from admin, but these custom fields are not visible in the profile section of an affiliate even to the admin. This makes no point to add custom fields if we’re unable to see these fields in the profile section after registering or to the admin.
Please correct these two problems asap.
Thank you.
- The topic ‘Affiliate Feature Suggestions’ is closed to new replies.
