Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › All products section is totally messed up
- This topic has 2 replies, 3 voices, and was last updated 7 years, 1 month ago by
- March 29, 2019 at 2:12 am #55118
richard.cannasolutions
ParticipantAfter loading all of the products via the vendor area, I went to the Woocommerce>All Products section. There I came to realize that there is a column that is not placed properly and it is all smushed up. I would like to see if there is a solution to this. I have provided an image for this so you can see the problem
You must be logged in to view attached files. - March 29, 2019 at 1:27 pm #55193
EK
ParticipantDid you try un-checking some items in the screen option bar in the admin panel? 😉
This happens when you have a lot of data to display and there is not enough width. I disabled a few options which I did not need to enable good display.
The screen options tab can be found on the top right. Maybe this helps 😉
Btw, I am not from wclovers team.
Cheers,
AK - March 29, 2019 at 5:23 pm #55227
Well, this is not messed. It’s WP very old issue, but nothing to do.
You may disable few columns from this product table using “Screen Option” – https://ibb.co/Y7cNLzG
- The topic ‘All products section is totally messed up’ is closed to new replies.
