Anyway to reset permalinks?
Viewing 1 reply thread
    • #109785
      memoryengravers
      Not sure what happened, but I have messed up the permalinks.
      Even setting them to plain and default, saving, refreshing the wp dashboard, I can no longer access the store manager (page not found) url is:
      store-manager?settings#wcfm_settings_form_marketplace_head
      I would like the urls to go back to the way they were working, with the “post” setting, but that does not work.
      Is there anyway to reset the permalinks without using the wordpress dashboard ?
    • #109926
      Please go to wp-admin -> WCFM Options -> be sure “Store Manager” page is set over there.
      If no, possible you had deleted that page by mistake. Please restore that and check once.
