Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Are ACF PRO 5.7.7 compatible? Its Missing a Lot of settings.
- This topic has 6 replies, 2 voices, and was last updated 7 years, 2 months ago by
- November 23, 2018 at 2:37 pm #37735
acaua
GuestHi, Is Wcfm-ultimate + Dokan pro vendor, Compatible with ACF PRO 5.7.7?
Inside Edit group field, almost all the fields settings did not works inside wcfm, if I access from wp-admin works as it should.
TOP BUGS:
1-Add new choice for checkbox (Allow ‘custom’ values to be added)
2-Conditional logic , Character Limit, append,Preppend,Layout Horizontal
3-its possible to show ACF without the WCFM css customization? The standard original layout ( that appear on Wp-admin) of ACF PRO its fantastic,clean and 100% working. - November 27, 2018 at 7:33 am #38303
Yeah that’s right, all Toolset field options are not available under WCFM product manager.
We are working on this and will be added all these support very soon.
- November 28, 2018 at 10:05 am #38493
acaua
GuestToolset not, ACF PRO
THank you for your answer.
Waiting for a new updating with this features.There is some Estimated Time ?
The option to use ACF PRO was the main decision to use WCFMU - December 10, 2018 at 8:30 pm #39571
acaua
GuestHi, There is some Estimated Time for compatibility with ACF PRO 5.7.7 ?
- December 11, 2018 at 7:15 am #39609
We are working on this.
I will update you soon on this.
Thanks for your patience.
- December 20, 2018 at 9:58 am #40440
acaua
GuestHello, i saw that in last WCFM update 5.2.5 , That you look to ACF – ACF PRO..
But was some bugs below fixed??
2-Conditional logic , Character Limit, append,Preppend,Layout Horizontal… - December 20, 2018 at 11:29 am #40460
WCFM not yet compatible with ACF all conditional logic.
We will add those soon.
- The topic ‘Are ACF PRO 5.7.7 compatible? Its Missing a Lot of settings.’ is closed to new replies.
