Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WC Marketplace › Barcode Scanning
- This topic has 1 reply, 2 voices, and was last updated 6 years ago by
- February 22, 2019 at 9:23 pm #49579
Craig
ParticipantIf I install the wooCommerce Barcodes ( https://woocommerce.com/products/woocommerce-order-barcodes/ )
What does the process look like for the vendor to scan the codes. How do that do that? Do they need some kind of app? or if they are on their phone and logging into their vendor dashboard is there a function to “scan barcode”?
Excerpt for the WooCommerce barcode sales page
“Using the built-in barcode scanner, you can quickly complete orders or check customers in – this allows you to use the barcode as a robust (yet simple) e-ticket solution for any type of event, booking or reservation.” - February 23, 2019 at 7:01 am #49656
Frankly, we are not very sure with this. But, I think any bar code scanner APP may read this, you may try with your phone apps.
It will be best for you to contact this plugin author directly.
- The topic ‘Barcode Scanning’ is closed to new replies.
