Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Appointment › Book directly on gCal two sync
- This topic has 1 reply, 2 voices, and was last updated 6 years ago by
- August 9, 2019 at 4:59 pm #75990
diego
ParticipantThis is my situation:
each Vendor has many resources that can be booked independently (also directly on gCal).I thought about creating a staff member for each Vendor resource.
Analyzing the operation of the wc-appointment plugin and reading their forum I realized that I have to consider a behavior that in my case is not good: gCal.
In fact, if a Vendor takes an appointment directly on gCal, all the slots defined by quantity will be occupied for the duration of the appointment so ALL the resources will be not available.
Is there the possibility of associating a staff member with a personal calendar?
Possibly the ideal would be within the same gCal account (Vendor Google Account)Thanks
Digeo - August 12, 2019 at 9:35 am #76226
Well, WC Appointment check availability by staff’s availability and it’s also sync Staff calendar.
Vendor calendar also sync. But availability does not check by vendor’s availability.
