Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › Bookings integration
- This topic has 7 replies, 3 voices, and was last updated 8 years, 2 months ago by
- June 25, 2017 at 8:25 pm #10704
Johann
GuestHi I have installed wc vendor pro as well as woocommerce bookings but when adding product the bookable items are not available in FREE version
- June 25, 2017 at 8:32 pm #10706
WCfM Forum
GuestHi Johann,
Admin also nit getting access to bookable product?
For vendor you have to give them access, as WC Vendors does not allow vendors to access Booking items.
Giving access to vendor is very easy, just go to WCfM Frontend Settings, be sure “Manage Booking” is unchecked and just hit “Save”. Now logged in as Vendor and check.
If you still have as query then please share with us.
Shhiv Narayan - June 25, 2017 at 8:39 pm #10709
Johann Liebenberg
ParticipantIt says I must install wc bookings but i have got woocommerce bookings plugin installed.
- June 25, 2017 at 8:41 pm #10710
Johann Liebenberg
ParticipantAttachments:
You must be logged in to view attached files. - June 25, 2017 at 8:44 pm #10712
Johann Liebenberg
ParticipantAll my plugins
- June 25, 2017 at 8:44 pm #10713
Johann Liebenberg
Participantplugins
You must be logged in to view attached files. - June 25, 2017 at 9:08 pm #10715
I think your Booking plugin is not right and also its too old version.
Even this version not compatible with your WooCommerce version.
Now WC Booking is at 1.10.3
WCfM is also not compatible with 1.9.5 veesion.
One more thing, please do not change any plugin’s original folder name, otherwise it will not detected as installed.
If you are just testing now then you may get Booking plugin from any gpl site also.
- June 28, 2017 at 5:41 am #10756
Hope you understand the issue.
If you have further query please feel free to share with us.
- The topic ‘Bookings integration’ is closed to new replies.
