Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Buddypress issues
- This topic has 4 replies, 2 voices, and was last updated 6 years, 11 months ago by
- September 25, 2018 at 12:39 pm #32517
andreasenglowski
i am having trouble with the buddypress integration:
1. If i go to the vendor backend tab in my bp profile it works as expected, but once i click somewhere in the dashboard i get redirected to the regular dashboard page. The problem comes with the last update i guess. Please check Screencast for detail.2. Is it possible to remove the store link tab from a vendors bp profile?
Many thanks in advance,
AndiAttachments:
You must be logged in to view attached files. - September 25, 2018 at 12:55 pm #32519
andreasenglowski
ParticipantThis reply has been marked as private. - September 25, 2018 at 4:52 pm #32538
1. Yeah, you are right. It’s not possible to render WCFM all screens under BuddyPress Profile.
2. Add this code for disabling that –
add_filter( 'wcfmmp_store_bp_menu_classes', function( $classes ) { return 'wcfm_custom_hide'; });
- September 26, 2018 at 8:41 am #32569
andreasenglowski
ParticipantHi, thanks for your fast reply.
1. sorry if my question is stupid but i am not understanding. isn’t that coming from the buddypress integration option of the front end manager (screenshot)? or should it work like that that you get redirected to the original dashboard page? because i am sure it was working under the tab before. sorry for bothering you but i am little confused π
2. many thanks that worked π
Kind regards,
AndiAttachments:
You must be logged in to view attached files. - September 27, 2018 at 1:44 pm #32669
1. sorry if my question is stupid but i am not understanding. isnβt that coming from the buddypress integration option of the front end manager (screenshot)? or should it work like that that you get redirected to the original dashboard page? because i am sure it was working under the tab before. sorry for bothering you but i am little confused
– It’s OK, feel free to ask anything π
NO, It shows only dashboard page under BuddyPress profile. But if vendor trying to manage anything else, like Product, Order etc.. then it redirect them to the actual WCFM dashboard page.Actually, it’s not possible to run all WCFM screens under BP profile, we have tried but no luck!
If we get any way out of this in future will definitely know you.
- The topic ‘Buddypress issues’ is closed to new replies.
