Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Bug in order amount with discount and commission ?
- This topic has 3 replies, 2 voices, and was last updated 6 years, 2 months ago by
- June 25, 2019 at 3:36 pm #69607
Jose
I found that something is wrong with the amount that show vendor order and admin order.
I have 80% vendor commission and a coupon discount of 15% and active commission after consider Vendor Coupon.
You can see that don’t show and calculate correctly.
Regards,
You must be logged in to view attached files. - June 25, 2019 at 10:50 pm #69667
Jose
ParticipantUpdate !
I found that only happens when a vendor (1) buy to another vendor (2) and use coupon discount of vendor (2).
Whith this info you can replicate the issue.
Regards,
- June 26, 2019 at 3:43 pm #69796
Jose
ParticipantUpdate !
I found the real issue, Vendor (1) can buy to vendor (2) with your own coupon discount. My update yesterday was wrong in the origin of the coupon.
This issue is very bad.
Regards,
- June 26, 2019 at 4:42 pm #69827
MemberOK< we will check this.
