Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Bug: Map on Vendors Listing Page not working when sidebar is customized
- This topic has 6 replies, 3 voices, and was last updated 6 years, 5 months ago by
Ramamurthy Krishnan.
- March 24, 2020 at 6:45 pm #112977
alexdezi
ParticipantThe map locations of the vendors are not shown when you customize the sidebar.
Here is a video of it: https://www.loom.com/share/f1c9210910d2484aaa56f6eeb368ee7cHope this helps!
- March 25, 2020 at 10:10 pm #113177
alexdezi
ParticipantI also noted another issue: On mobile on the page, where all vendors are shown, the location pins are there, however, when I click on any one, the latest added vendor is always shown. I deactivated the map for now..
- April 2, 2020 at 9:02 pm #114781
You have to keep any one store filter widget under sidebar.
- April 3, 2020 at 6:49 am #114951
alexdezi
ParticipantThis reply has been marked as private. - April 4, 2020 at 1:33 pm #115279
Please try this short code for this page – [wcfm_stores sidebar=”no”]
- April 7, 2020 at 1:30 am #116094
alexdezi
ParticipantHere is a quick video explaining what I mean: https://www.loom.com/share/57fd8e2c05854b34a428793486948bec
I also noticed that the locations pins are a bit off – when zoomed out, they are not in the exact location – when zoomed very close in, they are correct. Is this a known issue or did I set up something incorrectly?
- April 7, 2020 at 1:07 pm #116266
Ramamurthy Krishnan
Please go to store-manager->Settings->GEO Location and set your default map location in “Map Default Location” field and the check once.I also noticed that the locations pins are a bit off – when zoomed out, they are not in the exact location – when zoomed very close in, they are correct. Is this a known issue or did I set up something incorrectly?
If you set your location correctly it will appear at exact pin point set. Yes when you zoom out then it may look like a cluster as the area shortens, it is default Google Map feature.Thanks,
- The topic ‘Bug: Map on Vendors Listing Page not working when sidebar is customized’ is closed to new replies.
