Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Bug with membership plan
- This topic has 8 replies, 2 voices, and was last updated 6 years, 7 months ago by
- January 13, 2019 at 5:22 pm #43375
Jose
I found that there is an error with the latest updates.
Now, there is a first step option; Register or choose a plan. Therefore, if you select a plan, nothing will be shown if someone wishes to choose a plan.
And if a provider wants to change their plan, the link is sent to a plan page that is empty.In your demo, there is no such update.
Regards,
- January 14, 2019 at 4:37 pm #43511
“Now, there is a first step option; Register or choose a plan. Therefore, if you select a plan, nothing will be shown if someone wishes to choose a plan.”
– But, this new option does not effect this anyway. How may plans you have created?
- January 14, 2019 at 4:53 pm #43515
Jose
ParticipantThis reply has been marked as private. - January 16, 2019 at 8:45 am #43844
Kindly check WCFM Admin Setting -> Dashboard Pages -> be sure Membership and Registration page properly set over there.
- January 16, 2019 at 10:35 am #43867
Jose
ParticipantThis reply has been marked as private. - January 17, 2019 at 1:00 am #44030
- January 17, 2019 at 4:38 pm #44131
Please check at WCFM Admin Setting -> Dashboard Pages -> be sure Membership and registration pages set over there.
- January 17, 2019 at 4:59 pm #44137
Jose
ParticipantThanks again !!
With my other problem with ghost vendors, with Myphpadmin I erase some post and others, so was resolved !!
Regards,
- January 17, 2019 at 5:02 pm #44139
Thanks fro the update!
- The topic ‘Bug with membership plan’ is closed to new replies.
