Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Bug with membership plugin
- This topic has 6 replies, 2 voices, and was last updated 6 years, 5 months ago by
Jose.
- January 18, 2019 at 9:22 pm #44289
Jose
We found with the help of my hosting that this plugin make this errors:
1.- The REST API request failed due to an error.
Error encountered: (0) cURL error 28: Operation timed out after 10000 milliseconds with 0 bytes received2.- The loopback request to your site failed, this may prevent WP_Cron from working, along with theme and plugin editors.
Error encountered: (0) cURL error 28: Operation timed out after 10000 milliseconds with 0 bytes receivedWas check with Health Check and Hosting.
When disable just membership plugin, the error dissapear.Thank you
- January 19, 2019 at 6:18 am #44315
Can you please show me the exact error log?
Well, WCFM Membership has no REST API then how “REST API request failed due to an error”
WCFM Membership has no cURL request, then how “cURL error 28”?
- January 19, 2019 at 11:05 am #44360
Jose
We found that with membership plugin active you can see the error with health Check plugin.
And I have confirmation that bluehost found the exact error from backend, don’t know how, but they tell me the exact issue.I don’t saying a specific issue inside membership plugin, but affect to anothers components of wordpress.
Please see the attach 1 with membership active
Attach 2 when membership are disable.Regards,
You must be logged in to view attached files. - January 20, 2019 at 5:38 am #44440
MemberOK, we are checking this.
Thanks for the details.
- March 6, 2019 at 1:52 pm #51376
Jose
I forgot to ask you about that, do you found something ?
Because still the same error.
Regards,
- March 7, 2019 at 5:14 am #51436
We checked that, it’s server related issue – https://docs.presscustomizr.com/article/326-how-to-fix-a-curl-error-28-connection-timed-out-in-wordpress
Well, if WCFM related any plugin disable REST API then it’s own REST API will also stop working, but that’s not happening!
- March 7, 2019 at 1:09 pm #51540
Jose
ParticipantThis reply has been marked as private.
- The topic ‘Bug with membership plugin’ is closed to new replies.
