Black Friday
02Day 04Hr 37Min 15Sec
Black Friday
Bug (?) with shipment override per product
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Bug (?) with shipment override per product
Viewing 6 reply threads
    • #19998
      tsoulouhas
      If I choose to set a shipping cost per product then is no way to delete this rule!
      Even if I set the cost to none (empty), then the shipping cost for this product will be “free” instead of the global rate.
    • #20005
      Can you please know me which multi-vendor plugin you are using in?
    • #20007
      tsoulouhas
      WC Vendors Pro
    • #20010
      Thanks for your quick response.
      So you are using WC Vendors Pro default shipping as well, right!
    • #20112
      Bingal
      Keymaster
      This has been resolved with WCfM 3.5.8 release.
    • #20115
      tsoulouhas
      Yes, the problem solved! Thank you for your quick response! Amazing support
    • #20117
      Bingal
      Keymaster
      Welcome 🙂
  • The topic ‘Bug (?) with shipment override per product’ is closed to new replies.
