Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Bulk edit for price
- This topic has 5 replies, 3 voices, and was last updated 5 years, 5 months ago by
bobobrothers.
- August 26, 2019 at 10:27 am #78363
- August 29, 2019 at 3:33 pm #78994
MemberPrice bulk edit option already there – https://ibb.co/2Zr1yzZ
- August 29, 2019 at 4:07 pm #79005
djks74
ParticipantDear WCFM,
Thanks for the info but we cannot set like stock manager which can fill manual for all product in one page..
It would be nice if the price change can be like in stock manager or similar function like that! 🙂Thanks.
- August 30, 2019 at 8:24 am #79196
MemberWe will look into this!
- August 30, 2019 at 8:24 am #79197
- May 5, 2020 at 9:42 pm #127100
bobobrothers
ParticipantI have the same issue. I believe the stock manager definitely needs to include regular and sales price. It isn’t enough to manage stock if you cannot adjust the price at the same time. I am having to allow access to the backend so that vendors can use the plugin stockmanager there. However, we are having compatibility issues and permission troubles and it we are not able to make it work without giving vendors the capability to edit OTHER vendors’ products. Clearly, your front end has the ability to adjust capabilities and this must write those changes to the database. Those changes overwrite my attempts to manage capabilities on the back end using other plugins and I have to do so in order to make other things work. If your stock manager had the ability to adjust price, it eliminates a major reason I have to allow access to the back end.
