Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Bulki Linking Products to store
- This topic has 7 replies, 2 voices, and was last updated 6 years, 10 months ago by
- September 3, 2018 at 8:57 am #30628
gilservant
I was using WC Marketplace and have switched to this marketplace and I am in need of the ability to link products to a store through a bulk editing feature.
- September 3, 2018 at 9:28 am #30632
That’s great to know you want to switch to WCFM Marketplace.
First you just change your old vendor users role to “Store Vendor”
Hope, products will be auto-switched.
Actually, for WCFM Marketplace vendors are just author of their product. So hope your old products created by your vendors and they already assigned as author of those products.
- September 3, 2018 at 9:51 am #30640
gilservant
ParticipantThis reply has been marked as private. - September 3, 2018 at 12:20 pm #30655
Ahh … that’s more easy.
You just set that user vendor as Author for those imported product, that’s it.
- September 3, 2018 at 1:03 pm #30667
gilservant
ParticipantBut I have a lot already imported I just need to assign them to the vendor but it has to be a bulk format because there are many products
- September 3, 2018 at 1:19 pm #30668
OK, do you want to assign all these products to a particular vendor or different vendors?
- September 21, 2018 at 1:59 am #32145
gilservant
ParticipantI want to assign certain products to one Vendor and other products to another vendor. because of the number of products, this would be easy if I am able to bulk select and assign to a vendor. this feature is available to WC marketplace which I was using initially
- September 22, 2018 at 3:31 pm #32247
Kindly update WCFM Marketplace 1.1.0
We have added, in wp-admin and WCFM Product dashboard – both the “Bulk Edit” now have option to change products store.
- The topic ‘Bulki Linking Products to store’ is closed to new replies.
