Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › Calendar on Mobile – css problems
- This topic has 5 replies, 2 voices, and was last updated 7 years, 12 months ago by
- November 6, 2018 at 12:47 pm #35920
acauaferreira
ParticipantBooking calendar in mobile cut some days in calendar,and also if i try to move to righ to see the other days,the calendar dont move to right.
And if I rotate my phone to horizontal mode, the calendar does not adapt to full width.
To see the calendar in horizontal in full width i have to update the page,its not automatic.I use dokan,but also saw your demo has this problem
You must be logged in to view attached files. - November 6, 2018 at 3:54 pm #35961
What is screen resolution of this mobile you are testing with?
- November 6, 2018 at 5:07 pm #35972
acauaferreira
ParticipantIt’s a 4″
- November 8, 2018 at 8:36 am #36112
MemberAhh … that’s that reason.
It’s too small actually, WCFM dashboard design made for 5.1″ (mainly for iPhone’s standard size)Still I think you will get a better display in landscape view.
- November 8, 2018 at 11:09 am #36139
acauaferreira
Participant1-The main problem its that i can’t even move the calendar to right to see the last dates remaining, if the calendar could move instead block the remaining content would be a acceptable solution.
2-And if I try to see in landscape view, appear as the photos…he did not resize automatically if going from vertical to landscape.
The unique way to see in landscape view its to put the phone in landscape, and just after that, update the page. But a normal vendor will not discover this trick to see his calendar.
- November 9, 2018 at 10:41 am #36217
Memberwe will definitely look into this.
- The topic ‘Calendar on Mobile – css problems’ is closed to new replies.
